It is currently 11 Apr 2025, 21:36
PostPosted: 30 Nov 2007, 15:17
Car: '04 147 1,6 TI
Ma gandeam sa curat debimetrul prevetiv avand in vedere ca acu fro 2 luni am curatat si uleiat filtrul de aer. Si daca tot as face chestia asta vroiam sa incerc si un ECU reset impreuna cu un Throtle reset.
In primul rand a curatat cineva fr'odata debimetrul? Ceva feedback? Ce solutii de curatare ati folosit?
Am gasit procedura descrisa pe alfa156.net si astia ziceau ceva de Isopropanol si Glass cleaner. Cu Isopropanolul e ok, insa glass cleanerul asta e alcool diluat cu apa din cate stiu eu, si ma gandeam ca poate nu e cea mai inspirata alegere. Ce ziceti?
In al doilea rand a facut cineva ECU reset + throtle reset (tot la procedura descrisa pe alaf156.net si in alte parti ma refer)? S-au simtit ceva diferente dupa?
Quote:
Lumpy idle? High idle speed? Try a throttle reset.
How?
1. Switch on the ignition but don’t start the engine and leave for 90 seconds
2. Switch off the ignition and again leave for 90 seconds
3. Start the engine without touching the accelerator.
4. Leave engine to idle for at least ten minutes
5. Take the car for a spin and make sure you drive it in different styles including hard!
6. Idle should not be back to normal, but if not don’t panic. Try again.
Optional: ECU Reset:
1. Disconnect the battery for at least 45 minutes (making sure you have any radio codes!!)
2. Reconnect the battery.
This clears some of the ECU parameters. Then try the first steps again.
If this doesn’t work, then you will probably need to have the Idle Actuator reset using a
diagnostic system such as Examiner or AlfaDiag.
ex. Alfa 156 1.8 TS
ex. Alfa 147 1.9 JTD
ex. Alfa Spider 3.0 V6
Alfa 147 1.6 TI
PostPosted: 30 Nov 2007, 17:35
Car: 2.0 TS
http://forum.alfaclub.ro/viewtopic.php? ... debitmetru - asta pentru debitmetru.
pentru ECU probabil un search mai temeinic :peace:
AR 156 2.0TS 155CP
PostPosted: 30 Nov 2007, 18:18
Car: '04 147 1,6 TI
OK ma bad ca nu am cautat mai bine. In fine imi pare bine ca au mai facut si altii treaba cu curatarea MAF-ului.
LE: am cautat un pic cate ceva despre ECU reset pe forum si nu am gasit nimic.
ex. Alfa 156 1.8 TS
Alfa 147 1.6 TI
PostPosted: 01 Dec 2007, 01:26
E simplu resetul de ECU. O ora fara baterie, apoi pusa bateria, lasat 15 minute, jumatate de ora sa fii sigur, pornita masina, pus contact IGN(fara a porni motorul), lasat alte 15 minute, scos contact, lasat 5 minute, pornit motor, lasat in idle 15-20 de minute, oprit motor, si apoi aia e.
PostPosted: 01 Dec 2007, 09:14
Alexandrus Quote:
:roll2: :haha: :haha: hai frate ......... diagnoza de alfa nu aveti ?
PostPosted: 01 Dec 2007, 16:56
Nope, nici softul lor original nu are reset de parametrii ECU care sunt self-learning. Oricum, metoda e babeasca, dar daca aia care in general stiu ce spun afirma ca functioneaza, peme. Eu unul nu am incercat-o.
PostPosted: 01 Dec 2007, 19:58
Car: '04 147 1,6 TI
Meme Quote:
Pentru diagnoza trebuie o interfata ca asta plus Alfa Diag. Nu inteleg ce e de ras in povestea asta?
ex. Alfa 156 1.8 TS
Alfa 147 1.6 TI
PostPosted: 01 Dec 2007, 20:45
Si pe mine ma distreaza procedura de reset. Ma asteptam sa mai scrie ca trebuie sa ai o banana in torpedo pe timpul testului :)
Serios vorbind, nu ma pronunt, habar n-am.
 Post subject: Reset ECU
PostPosted: 18 Jan 2008, 15:12
Eu am personal o interfata Texa Navigator cu soft aferent Texa IDC si are in meniu o optiune "reinitializare parametri autoadaptabili"; normal ca am folosit-o :roll:
Am mai citit si pe net anumite instructiuni ce se fac dupa ce resetezi procesorul si am trecut la treaba.Vreau sa va spun (sper sa nu fie autosugestie), chiar functioneaza dupa ce alegi un alt mod de a conduce.Dupa ce se face resetul (ori cu soft, ori chestia cu bateria), se alege o 'harta' din programul ECU-lui prin felul tau de a conduce.
In cazul meu, neavand nevoie de multi cai putere acum iarna, am facut resetul si am condus in turatii mici (cca2500ture) imediat dupa aceea si automat a intrat in functiune harta de consum redus si putere mai mica (sper sa nu gresesc).Eu am simtit diferenta si la consum, dar mai mult la puterea masinii.O distanta de 360km care o fac mai des, de obicei inaintea resetului puneam cca.35 litri de benzina, iar acum pun cca.30 litri, in aceleasi conditii de mers (turatie, viteza); insa nici nu mai trage cand incerc sa bag talpa.
Daca cineva crede ca gresesc, rog sa ma corecteze.
Clar este ca dupa reset se intampla ceva; nu degeaba se cheama PARAMETRI AUTOADAPTABILI!
PostPosted: 19 Jan 2008, 00:35
:D Ai ghicit!!!
Este 1000% corect ceea ce ai scris. :D
PostPosted: 03 Feb 2008, 14:19
Car: AR 156 1.9 JTD
Eu am schimbat debitmetrul acum 4 luni dar nu am resetat nimic. E mai veche masina mea 1.9 JTD 110 cai din 2001 si d-aia n-am considerat ca trebuie sa dau reset. Comportamentul masinii s-a schimbat imediat dupa ce am montat noua piesa. Dar mi se pare ca consuma mai mult. Sa fie oare de la vremea rece de iarna sau de la ecu invatat sa mearga in "limp mode"?
Cuore Sportivo
