It is currently 12 Apr 2025, 20:51
 Post subject: Lumini de bord
PostPosted: 24 Mar 2010, 04:03
am si eu o problema la o alfa 159,mi se aprind doua lumini in bord,la prima scrie ceva de hillholder,banuiesc ca este ceva legat de suportul penrtu calcai,iar la a doua scrie"vehicle protection system unaveileble"insotit de un semn cu un volan si o cheie pe galben,acesta dispare daca inchid si pornesc din nou motorul,iar primul daca apas cu piciorul pe suportul de calcai,poate ma puteti ajuta cu un raspuns
 Post subject: Re: Lumini de bord
PostPosted: 24 Mar 2010, 09:22
Car: 2.0 TS
...the Hill Holder system helps drivers pull smoothly away from an upwards-facing hill start. Operating via the ESP longitudinal acceleration sensor when first gear is engaged and both clutch and brake pedals are pressed, the control unit maintains front calliper pressure for about 1.5 seconds after the brake pedal is released to eliminate the risk of rolling backwards and ensure a smooth pull away. Hill Holder does not operate when setting off downhill in first gear, but does so when reverse is engaged and the driver wishes to back uphill.
suport cu senzori pentru calcai ... buna asta!!!
AR 156 2.0TS 155CP
PostPosted: 25 Mar 2010, 02:24
iar am patit,imi apare "vehicle hillholder unavalaible,check hand book" imi apare un semn in bord si mi se aprinde si esp-ul,dak apas usor pe suportul pentru piciorul stang dispar ambele,nu inteleg
