It is currently 07 Jun 2024, 12:28
 Post subject: Lancia Hyena
PostPosted: 09 Sep 2008, 12:44
Intamplator am aflat despre acest model de Lancia. Articolul este in engleza si este preluat de pe http://www.conceptcarz.com/vehicle/z151 ... Hyena.aspx
The Lancia Hyena was designed and built by the Italian coachbuilding firm, Zagao. This series was the result of a Dutch Lancia dealer named Paul Koot, who tried to convince Lancia to create a limited-production coupe that was based on the Delta Integrale. This was a tribute to the Delta Integrale and its racing accomplishments on the rally circuit. The Hyena was introduced in 1986 and given a four-cylinder, two-liter, turbocharged engine that had eight-valves and 185 horsepower. A sixteen valve unit pushed the horsepower even higher, to 200. The car was given an aggressive stance with flared fenders and a proper suspension.
Reducing the overall weight of the vehicle brought it to 2500 pounds, a 15% decrease in comparison to the production EVO. Zero-to-sixty took only five seconds. Originally, Zagato and Koot tried to convince Lancia to allow for 500 examples to be produced. Lancia/Fiat declined. The duo tried another approach to get their idea into production - they requested that Fiat sell them Integrale chassis and components so they could build the machine themselves. Fiat again refused. So Koot and Zagato went ahead with production anyways, managing to create 26 examples.
The way they went about making these cars would probably was not the most efficient, but it worked. They purchased Integrale sedans and shipped them to Holland. The interior and bodies were removed. They were then sent to Italy where the Zagato company outfitted the chassis with new aluminum coupe bodies. The chassis, mechanical components, and body were then resent back to Holland where they were assembled. This made for a very hefty price tag, a staggering $75,000.
1993 Lancia Hyena
Year: 1993
Make: Lancia
Model: Hyena
Engine Location: Front
Drive Type: AWD
Body / Chassis: Aluminium
Production Years for Series: 1992 - 1993
Body Designer: Zagato
Weight: 2530 lbs | 1147.6 kg
Engine [Optional Engines]
Engine Configuration I
Cylinders 4
Water-Cooled
Aspiration/Induction Turbocharged Garrett T-3
Displacement 2.00 L | 122 cu in. | 1999.6 cc.
Valves 8 valves. 2 valves per cylinder.
Valvetrain DOHC
Horsepower 185.00 HP (136.2 KW) @ 5750.00 RPM
Torque 220.00 Ft-Lbs (298.3 NM) @ 3500.00 RPM
HP to Weight Ratio 13.7 LB / HP
HP / Liter 92.5 BHP / Liter
Standard Transmission: Gears 5
Transmission: Manual
 Post subject: Re: Lancia Hyena
PostPosted: 09 Sep 2008, 13:26
Car: 156 1.9 mJTD
Aduce destul de mult cu Brera din cateva unghiuri. :D
PostPosted: 09 Sep 2008, 14:16
Aduce mai degraba cu Alfa Romeo SZ, desenata tot de Zagato in aceeasi perioada ;)
Razvan Patrascu
Alfa Romeo GTV V6 3.2 270CP
Alfa Romeo 147 1.9 JTD 101CP
PostPosted: 09 Sep 2008, 15:38
Si mie mi s-a parut ca spatele aduce a brera si fata a SZ
PostPosted: 10 Sep 2008, 10:02
nu conteaza a ce aduce , e frumoasa foc , ceva deosebit , in stilul pur italienesc :D
1981 Fiat 131 (prima iubire)
1962 Fiat 600D dragoste la prima cheie
2005 Iveco daily 35C10
Semnatura de om serios !
PostPosted: 10 Sep 2008, 11:26
Car: 159-Brera-Spider916
mie imi pare a concept din anii 70 ,futuristic atunci destul de invechit acum,una peste alta merita vazuta live inainte de alte concluzii
PostPosted: 13 Oct 2008, 09:45
Arata f misto....oricum se vede ca este concept!Oricum Sz...era de serie...si era cam la fel!
PostPosted: 13 Oct 2008, 13:16
Ahaa! Acuma stim de unde s-a inspirat Giugiaro cand a desenat spatele Brerei :lol:
PostPosted: 13 Oct 2008, 13:48
Mai veche dar cam seamana? :(
"Ho scelto di guidare italiano...Una scelta che mi ha cambiato la vita
C'è qualcosa che lega ogni pilota alla sua Alfa Romeo
Noi lo chiamiamo:Cuore Sportivo"...
