In loc sa va dati cu parerea aiurea fara sa aveti vreo baza solida, un simplu google sau cautare in wiki o sa va lamureasca si abia apoi postati, induceti in eroare lumea.
Uite
AICI in Wiki ce inseamna cifra octanica. De aici citez:
Quote:
It should be noted that octane rating does not relate to the energy content of the fuel (see heating value), nor the speed at which the flame initiated by the spark plug propagates across the cylinder. It is only a measure of the fuel's resistance to autoignition.
si
Quote:
It might seem odd that fuels with higher octane ratings explode less easily, yet are popularly thought of as more powerful. The misunderstanding is caused by confusing the ability of the fuel to resist compression detonation as opposed to the ability of the fuel to burn (combustion).
Limpede? Este doar un simplu PLACEBO faptul ca "masina trage mai bine", datorita sunetului schimbat de la motor...
Dar daca voua chiar vi se intampla sa vi se mareasca puterea daca bagati benzina cu cifra octanica marita, inseamna ca aveti ceva in neregula cu motorul. Iata de ce:
Quote:
engines perform best when using fuel with the octane rating for which they were designed and any increase in performance by using a fuel with a different octane rating is minimal or even imaginary, unless there are carbon hotspots, fuel injector clogging or other conditions that may cause a lean situation that can cause knocking that are more common in high mileage vehicles, which would cause modern cars to retard timing thus leading to a loss of both responsiveness and fuel economy
De aia Vali merge mai prost cu OMV 100 si merge beton cu Agip 95. Si bag numai de 95!
Numai bine,
Alex.
