It is currently 16 Nov 2024, 00:47
PostPosted: 27 Apr 2016, 20:06
Salutare, de cateva saptamani a mea masina a inceput sa imi faca probleme, din senin in timpul mersului ramane fara putere fara sa se aprinda nimic in bord si fara sa dea vreo eroare pe tester. Pur si simplu nu vrea sa se tureze mai mult de 2200 ture desi turbina se aude ca intra, e ca si cum ar intra intr-un safe mode. Atasez si cateva loguri facute cu Fiat ecuscan pentru a putea primii indumarile necesare. Mentionez ca tipul de la care am luat masina mi-a spus ca are EGR si DPF off, varianta de motorizare este cea 1.9 8v 120 cp. Astept parerile voastre
READING PARAMETERS:
Battery voltage: 13.822 V
Odometer: 0.0 km
Odometer at last programming: 11899.1 km
Overrev count: 0
Number of programmings: 2
Total fuel quantity: 4.602 mm³/i
Inj. correction Cyl. 1: -0.52 mm³/i
Inj. correction Cyl. 2: -1.56 mm³/i
Inj. correction Cyl. 3: -0.15 mm³/i
Inj. correction Cyl. 4: 2.16 mm³/i
Inj. correction Cyl. 5: mm³/i
Intake air quantity: 485.5 mg/i
Desired intake air quantity: 488.0 mg/i
Intake air quantity signal period: 2.343 ms
Air temperature (MAF): -40.00 °C
Air temperature (Boost/Manifold): 47.86 °C
Air temperature signal (Boost/Manifold): 2145.3 mV
Baro pressure: 1008 mBar
Boost pressure: 1036 mBar
Desired boost pressure: 982 mBar
Boost pressure signal: 1671.3 mV
Boost control/solenoid: 74.96 %
EGR valve opening: 4.00 %
EGR control: OFF
Throttle angle: 5.00 %
Inlet circ. solenoid valve opening: %
Fuel temperature: 29.76 °C
Fuel temperature signal: 2912.6 mV
Fuel pressure (Gauge): 270.30 bar
Desired fuel pressure: 270.00 bar
Fuel pressure sensor: 1119.1 mV
Pressure regulator opening (MPROP): 35.61 %
Pressure regulator opening (DRV): %
Fuel consumption: 0.5400 l/h
Fuel gauge: 79.078 %
Fuel pump relay: ON
Engine oil pressure: Normal
Engine temperature: 97.46 °C
Engine oil level: %
Gas pedal position: 0.00 %
Gas pedal position signal 1: 1246.1 mV
Gas pedal position signal 2: 918.7 mV
Accelerator pedal track: Acc. Pot. Track 1
Brake pedal switch: Released
Brake light switch: OFF
Clutch pedal switch: Pressed
Fan speed: 1
Fan 1st speed: ON
Fan 2nd speed: ON
A/C request:
A/C pressure sensor: mBar
Glow plug circuit: OFF
Failure indicator light: OFF
Engine temperature light: OFF
Glow plugs indicator light: OFF
Water in fuel warning light: OFF
PostPosted: 27 Apr 2016, 21:55
pai suntem in Siberia de debitmetrul arata -40?verifica debitmetrul sa nu fie murdar sau dus.scoate mufa si da o tura sa vezi ce se intampla.
PostPosted: 27 Apr 2016, 21:56
Nimeni, nimic? intre timp am verificat si furtunele de la vacum si totul pare ok.
PostPosted: 27 Apr 2016, 21:57
am scos si debitmetrul si nimic. nici o schimbare. masina nu face tot timpul asa, are momente si imediat ce opresc si pornesc motorul totul revine la normal
PostPosted: 27 Apr 2016, 22:05
cosmin.manolake Quote:
si corectiile pe injectoare sunt mari,mai ales 2 si 4
PostPosted: 28 Apr 2016, 02:56
@cosmin: mai ai putina rabdare sa vada si altii postul, poate primesti ceva indrumari. Insa -40 chiar arata suspect.
Predecesorul posesor ti-a zis ca a anulat EGR si DPF, dar l-ai intrebat daca a facut si ajustarile necesare in soft?
PostPosted: 28 Apr 2016, 07:44
da, a spus ca sunt anulate atat fizic cat si din soft plus ca a dus-o undeva la 150 cp
PostPosted: 28 Apr 2016, 09:20
Admisia cum se prezinta?
PostPosted: 28 Apr 2016, 09:36
Cel mai probabil atunci cand s-a facut dpfoff au fost anulate la pachet mult mai multe DTC-uri decat trebuia (de obicei cele legate de rail), aceasta fiind explicatia faptului ca nu ai nici o eroare stocata.
@cristianmiu: ce treaba are admisia? vorbim de un 8v...
Logul facul la ralanti este irelevant, incearca sa loghezi in sarcina (treapta a 3-a, pedala la fund incepand cu 1500rpm) urmatorii parametrii si posteaza rezultatul aici
- Rpm
- Total fuel quantity
- Desired fuel pressure
- Fuel pressure (Gauge)
Bafta!
PostPosted: 28 Apr 2016, 11:39
astazi, cand ajung acasa am sa fac si logul in mers. multumesc pentru ajutor
PostPosted: 28 Apr 2016, 18:11
asta este ultimul log in mers in treapta a 3-a
Engine speed: 5060 rpm
Total fuel quantity: 21.165 mm³/i
Inj. correction Cyl. 1: 0.67 mm³/i
Inj. correction Cyl. 2: -3.94 mm³/i
Inj. correction Cyl. 3: 0.38 mm³/i
Inj. correction Cyl. 4: 2.87 mm³/i
Intake air quantity: 699.5 mg/i
Desired intake air quantity: 681.5 mg/i
Intake air quantity signal period: 0.143 ms
Air temperature (MAF): 23.66 °C
Air temperature (Boost/Manifold): 44.16 °C
Air temperature signal (Boost/Manifold): 2306.6 mV
Baro pressure: 1011 mBar
Boost pressure: 1840 mBar
Desired boost pressure: 1803 mBar
Boost pressure signal: 2937.0 mV
Boost control/solenoid: 46.14 %
EGR control: OFF
Fuel temperature: 38.86 °C
Fuel temperature signal: 2482.5 mV
Fuel pressure (Gauge): 747.20 bar
Desired fuel pressure: 695.00 bar
Fuel pressure sensor: 2150.2 mV
Pressure regulator opening (MPROP): 32.07 %
Fuel consumption: 12.9600 l/h
Fuel gauge: 72.071 %
Fuel pump relay: ON
Engine temperature: 93.46 °C
Engine oil level: %
Gas pedal position: 100.00 %
Gas pedal position signal 1: 3758.1 mV
Gas pedal position signal 2: 1861.9 mV
Vehicle version: with DPF
Lambda sensor signal: V
Lambda oxygen concentration: %
Pre-catalyser temperature: 460.66 °C
PostPosted: 28 Apr 2016, 22:56
salut! inca o chestie care am observat-o in seara asta, cand nu mai am putere la motor nu mai pot cupla nici cruise control si releul negru mare de langa mufa obd este foarte cald.
PostPosted: 28 Apr 2016, 23:08
Parametrii sunt corecti la prima vedere, mai putin injectoarele 2 si 4 care sunt pe aratura rau.
Si nu inteleg faza cu EGR la 4%, stiu ca EGR-ul scos din soft indica 100% pe tester, evident aici ar fi necesara o parere avizata, nu a mea.
Aaa, si nu am vazut nici acum si nici in postarea initiala logo-urile pentru DPF, chiar daca e scos ar trebui sa avem o constanta macar, presiune -1, chestii de genul, pe mine ma depasesc resoftarile, tot un coleg in domeniu te lamureste.
PostPosted: 29 Apr 2016, 04:56
intr-un log mai vechi la mine 1.9 jtd,16v:
Engine speed: 4063 rpm
Desired intake air quantity: 1200,0 mg/i
Intake air quantity: 1156,0 mg/I
Desired boost pressure: 1474 mBar
Boost pressure: 1927 mBar
cand ajungeam la aceasta presiune motorul intra in "limp mode",tin minte ca tzzivii spunea ca presiunea trebuie sa fie de 1,7+1bar (presiunea atmosferica).problema sa rezolvat prin schimbarea turbinei.
la tine se apropie:
nu sunt un specialist,doar imi dau cu parerea,poate asa invatam mai multe despre motoarele noastre.
PostPosted: 29 Apr 2016, 09:45
S-ar putea sa se invarta pe langa ea mult si bine, cu DTC-urile anulate va fi foarte greu sa gaseasca problema.
Oricum, egr-ul este anulat, valoarea de 4% este corecta.
PostPosted: 29 Apr 2016, 20:10
astazi am demontat si senzorul de pe admisie si corpul clapeta, ambele au fost foarte murdare si le-am curatat, am schimbat si filtrul de motorina, totul in zadar...
File comment: asa arata inainte de curatare
PostPosted: 29 Apr 2016, 20:40
pana la bucuresti ai 140 km,vorbeste cu ILuzoriu sau tzzivii sa te programeze pentru o verificare.stiu cum este cu lipsa de putere,am stat foarte mult timp cu aceasta problema.
PostPosted: 29 Jun 2016, 00:13
Car: Alfa Romeo 159,170cp
Ai rezolvat problema?Daca da cred ca au fost injectorele mai ales cel de pe cil 2.Ala era praf,nu ti-a spus mecanicul ?
Alfa 159,2.0,170cp
Alfa 147 1.6 ts 120cp
