"You don't own your car" : stire proasta
https://www.alfaclub.ro/forum/viewtopic.php?t=23510
Page 1 of 1
Author:  zveroboy78 [ 23 Apr 2015, 21:16 ]
Post subject:  "You don't own your car" : stire proasta
Dupa ce ne-au potcovit cu plasticaraie si electronice, fabricantii auto (amerloci, deocamdata) vor sa ne interzica sa ne reparam singuri masinile.
https://www.yahoo.com/autos/s/gm-ford-o ... 00229.html
Citatul asta e chiar remarcabil:
"What GM, and even tractor companies like John Deere, argues is that you, as an owner, don’t actually own your car. Rather, you’re sort of just borrowing it for an extended amount of time and paying for the rights to use the technology. If it sounds ridiculous— it is. But it gets even more ludicrous.
According to the Electronic Frontier Foundation, John Deere argued that “letting people modify car computer systems will result in them pirating music through the on-board entertainment system.”
That’s right— pirating music. Through a tractor."
In acelasi spirit se pare ca pe modele recente de BMW si Audi nu mai exista joja de ulei, e optionala si tre sa dai banu' jos, daca te crezi mai dastept decat Prealuminatu' Senzor.
Asta va da si mai multa greutate celebrei fraze a mecanicilor de reprezentanta cand iti pica ceva in garantie : "Da n-are nimic, dom'le, e normal!"
Daca stirea ajunge realitate, cre' ca-mi iau un UAZ 469b si ma retrag in Muntii Altai sau in Siberia. Probabil vine si tov. Coman, sper!
Author:  yux_mm [ 23 Apr 2015, 23:49 ]
Post subject:  Re: "You don't own your car" : stire proasta
Pai in sensul asta am 2 optiuni: raman la tigaia asta pana o mananca de tot rugina sau ma intorc la carburator...
"According to the Electronic Frontier Foundation, John Deere argued that “letting people modify car computer systems will result in them pirating music through the on-board entertainment system.”
- asta e ca faza aia: berea este primul pas catre spirtul tras prin paine...
Author:  marius [ 25 Apr 2015, 08:45 ]
Ciudat ca ideea asta sa se fi nascut tocmai de la americani, acolo unde simtul proprietatii face parte din ADN-ul lor si unde unde oamenii sunt gata sa-si apere ce-i al lor cu pusca-n mana.
Author:  alexmirica [ 25 Apr 2015, 08:59 ]
Pai la cat de prosti sunt ei in general, parca genetic, nu sunt in stare sa repare bine masinile. S-au intamplat multe accidente din cauza montajului prost al pieselor de schimb.
Author:  Jaggguar [ 25 Apr 2015, 11:58 ]
In State, cei mai multi dintre ei, NU sunt proprietarii masinilor pe care le conduc. Au ceva sistem similar cu leasingul operational de la noi.
Author:  zveroboy78 [ 27 Apr 2015, 11:41 ]
Vine din tara unde unii s-au gandit sa breveteze genomul uman! De parca l-ar fi inventat ei!
Da' apa rece? N-o breveteaza nimeni? Ca sa faca bani stand in fund cand noi bem apa, alimentand-i contul?
E vorba de muuult malai si "clientul captiv", visul oricarui copchil cu muci in freza de la marketing.
Praftic, vei avea garantie 2-3ani, ulterior nu, dar reparatiile tot la reprezentanta, tot pe banii tai... si cand masina o sa aiba 15 ani, tot la reprezentanta o sa trebuiasca sa-i pui lichidu' de parbriz, la preturile care " este"
Poate exagerez... Da' ati prins ideea.
Author:  ibiza [ 27 Apr 2015, 12:16 ]
Pai, da, pentru ca, corporatiile au ca scop, o sa radeti, profitul. Baietii incearca sa iti ia cat mai multi bani cum pot. Si Renault parca face ceva similar cu masinile lor electrice.
Un scandal mai interesant este legat de Nestle si demersurile lor de a privatiza resursele de apa. Cred ca le-a si iesit in unele republici bananiere, nu stiu sigur. Cand or sa privatizeze astia si aerul, nu cred ca ne va mai pasa daca masina este proprietatea noastra sau daca are joja de ulei...
Eat Soylent Green :disgust1:
Author:  comanr [ 28 Apr 2015, 13:36 ]
cred ca este ok, pana la urma cat de fraier sa fii sa ai pe numele tau un plastic ambulant calculat sa se arunce dupa maxim 5 ani, chiar tre sa fii prost sa ti doresti sa ai in proprietate asa ceva.
"...in avioane de hartie..."
