It is currently 21 Nov 2024, 21:18
Post new topic  Reply to topic  [ 1 post ]
 Post subject: Eroare airbag 156
PostPosted: 13 Jan 2015, 15:20
Car: Afla Romeo 156 1.8TS
Am avut pana astazi un martor la airbag aprins in bord la o afla 156 1.8 benzina din 2000. Am scanat si am sters eroarea cu mufa vagkkl. Eroarea este urmatoarea si as dori sa-mi spuneti daca trebuie sa-i acord vreo importanta si ce trebuie facut. Inca nu mi-a reaparut la loc insa precizez ca nu scria ca la alte erori cum ca ar fi stocata in ecu si poate sa nu fie de acum. Multumesc!
"The Airbag activating circuit indicated by the code is shorted to Ground. This may be caused by a faulty circuit, Squib or ECU.
Inspect the wiring and connectors for opens, shorts and weak connections.
Observe the following safety rules:
- Do NOT place anything on the steering wheel or dash, or work directly in front of them.
- Turn the Key OFF and wait at least for 10 minutes, then disconnect the battery and wait for 15 minutes before unplugging the Airbag connectors.
- Inspect the wiring and connectors for weak connections or damage.
- Reassemble the connectors in the reverse order, and reconnect the battery as the last step.
- Turn the ignition on and erase all the fault codes. Cycle the key off for a few minutes, then back on and check the fault codes.
WARNING: Improper access to the Airbag circuitry may cause the Airbag(s) to deploy or malfunction later, which may result in serious injury or death.
DO NOT MEASURE OR CONNECT ANYTHING TO THE AIRBAG SIDE OF THE CIRCUITRY without consulting the appropriate service literature first. Follow the local Airbag system repairs regulations
The reason for this fault is Open circuit
The current status of the fault is Intermittent
The error counter value is 133"
