It is currently 02 Dec 2024, 07:10
 Post subject: Alfa Romeo Alfetta GTV6
PostPosted: 30 Sep 2006, 05:44
Masina este a unui prieten,este reconditionata total,motorul este V6 2.5 benzina (injectie) si dezvolta aprox. 160 cp (stock)
Prezinta mici modificari la exterior.Cateva date tehnice ale acestui model:Type 2+2 FHC (20)
Designer Giugiaro
Number of doors 3
Wheelbase 2400 mm 94.5 in
Track front 1373 mm 54.1 in
rear 1352 mm 53.2 in
Length 4260 mm 167.7 in
Width 1664 mm 65.5 in
Height 1330 mm 52.4 in
Length:wheelbase ratio 1.78
Ground clearance 120 mm 4.7 in
Kerb weight 1210 kg 2668 lb
Weight distribution
(Front)
Fuel capacity 75
litres 16.5
UK Gal 19.8
US Gal
Drag coefficient 0.390 Type V-6
in 60.0° vee
Wet sumped
SOHC
12 valves total
2 valves per cylinder
Main bearings 4
Construction light alloy block & head
Bore × stroke 88.00mm × 68.30mm
3.46 in × 2.69 in
Bore/Stroke ratio 1.29
Displacement 2492 cc
(152.071 cu in)
Unitary capacity 415.33 cc/cylinder
Compression ratio 9.00:1
Fuel system Bo L-Jet fuel inj.
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter N
Max. output
(Net) 160.2 PS (158.0 bhp) (117.8 kW)
@5600 rpm
Max. torque
(Net) 213.0 Nm (157 lbft) (21.7 kgm)
@4000 rpm
Maximum rpm 6000 rpm
Coolant Water
Specific output 63.4 bhp/litre
1.04 bhp/cu in
Specific torque 85.47 Nm/litre
0-60mph 8.80s Top speed 212 km/h (132 mph)
Fuel Consumption 19.1/36.7/28.6 mpg (UK) urban/56mph/75mph
Power-to-weight 130.58 bhp/ton
PostPosted: 30 Sep 2006, 05:54
Cateva poze facute recent
PostPosted: 30 Sep 2006, 06:27
Cateva poze cu modelul original,de serie
PostPosted: 30 Sep 2006, 08:18
Prea tare, imi place de mor modelul asta! Vii cu ea la intalnire? :D
PostPosted: 30 Sep 2006, 10:09
Si mie imi place foarte mult.Fiind un prieten apropiat al propietarului am urmarit proiectul inca de la inceput.El a mai participat la o intalnire organizata de acest club (se intampla anul trecut cred) atunci conducea o Alfa Romeo Alfetta GTV rosie,cu motor 1.8 carburatie,pe care o mai are si care este in prezent de vanzare.S-ar putea sa mai existe poze cu ea pe acest forum insa nu imi mai amintesc exact unde.Daca nu le voi mai gasi voi posta unele.Momentan nu stiu exact daca va veni,ramane sa-l intreb.Eu nu am mai intrat pe acest forum de mult timp,asa ca nici nu mai stiu cand se mai organizeaza intalniri.Daca esti amabil sa-mi spui si mie cand se mai petrec astfel de evenimente,ti-as fi recunoscator. :D
PostPosted: 30 Sep 2006, 10:35
Am gasit topicul mai vechi despre care vorbeam si care este de fapt alcatuit tot de un amic de-al meu,pe nume Achim.Se afla in rubrica dedicata modelelor mai vechi Alfa Romeo 33,75,145,146,etc..unde sunt multe detalii si poze cu GTV-ul acela rosu,tot cu stopuri rotunde.Topicul se numeste Alfa Romeo GTV/Spider.Propietarul celor 2 masini este acelasi,daca ai participat atunci la intalnirea la care a fost prezent s-ar putea sa-l cunosti.Il cheama Alex,iar prietenii ii spun "Cocker".Locuieste langa Gradina Icoanei.
PostPosted: 30 Sep 2006, 11:08
frlicitari lui alex pt gtv-ul asta. e mai reusit decat cel rosu. Imi plac amandoua dar asta e mai ok. Si pe langa toate astea e GTV6 :D
Razvan Patrascu
Alfa Romeo GTV V6 3.2 270CP
Alfa Romeo 147 1.9 JTD 101CP
PostPosted: 30 Sep 2006, 21:33
Da' chiar, cand mai vine Cocker la intalnire? Intalnirile au loc in fiecare duminica la ora 13 la Piata Constitutiei (rondul ala mare din fata Casei Poporului), iar in cazul in care piata e ocupata se muta la Academia Militara (cum se intampla si maine).
PostPosted: 09 Apr 2007, 20:41
Un amic din Irlanda tocmai si-a cumparat un GTV6 din 1982,IMPECABIL, si cireasa de pe tort...face parte dintr-o serie foarte limitata(15 exemplare) modificata de un garaj specializat Alfa Romeo din UK-Chaparral.Masinuta are mai mult de 200 de cai iar interiorul este custom,scaune si tapiserie de piele speciale.
Despre pret nu va mai spun nimic,ca iar ma apuca durerea de inima cand imi aduc aminte.A,si nici nu se plateste taxa de inmatriculare!
PostPosted: 10 Apr 2007, 21:41
Cu cateva zile inainte am vazut acest model intr-o parcare si ma tot gandeam ce model e....arata super.....
Alfa Romeo GT 2.0 JTS 165cp
ex:Alfa 155 1.9 TD 1993 90cp
