It is currently 02 Feb 2025, 11:57
PostPosted: 25 Jan 2007, 15:29
Car: '04 147 1,6 TI
Am deschis subiectul asta ca sa fie evitate intrebari de genul "Cat sunt de fiabile?", "Ce se strica?" etc
Incep cu cel mai recent articol din Februarie 2005 Auto Italia:
Image Image Image Image Image Image
Al doilea articol e din revista Autocar din Octombrie 2004:
Image Image
Al treilea articol e tot din Auto Italia din Aprilie 2000
Sursa http://www.alfa156.net/
# Check that Air Con is working
# Look for corrosion over windscreen and on roof
# Listen for clunks from front ball joints
# Cam variator rattles from Twin Sparks
# Check for flaky paint on front bumper
# Make sure rear brakes haven't seized/corroded
# Check if all interior/dashboard lighting is still working
# Check engine under tray isn't smashed - it'll ground out otherwise.
# Check suspension for creaks over bumps
# Check alarm arms properly
# Check for oil leaks (it stungs a fortune for leaky balancer shaft seals)
# Run air con on coldest setting whilst you test drive it then feel round
the spongy gasket on the plastic housing in the middle of the bulkhead to see if it gets wet.
# Test drive it in the wet and go through every puddle you can find - then check
the carpets for water.
# Check edge of drivers seat for wear on the piping.
# Check when the cam belt was last changed!
ex. Alfa 156 1.8 TS
ex. Alfa 147 1.9 JTD
ex. Alfa Spider 3.0 V6
Alfa 147 1.6 TI
PostPosted: 25 Jan 2007, 16:23
Multumim mult, Dany!
O idee foarte buna ;)
PostPosted: 25 Jan 2007, 16:54
Super tare!
Oricum e cam unanim valabil...ce este acolo!
PostPosted: 25 Jan 2007, 17:59
Car: '04 147 1,6 TI
Pe www.alfa156.net mai sunt o gramada de tips-uri si raspunsuri la FAQ.
ex. Alfa 156 1.8 TS
Alfa 147 1.6 TI
PostPosted: 25 Jan 2007, 23:31
:thanks: :goodpost:
Users browsing this forum: No registered users and 10 guests
