It is currently 08 Feb 2025, 16:35
 Post subject: PROBLEME ALFA
PostPosted: 24 Mar 2010, 11:54
SAL. AM SI EU DOUA PROBLEME CU ALFA MEA.[ 156 2.4JTD]IN URMA CU 2 SAPTAMANI AM AVUT UN ACCIDENT SI AM REPARATO, BINEINTELES. DAR MI-A RAMAS UN ZGOMOT FOARTE PUTERNIC LA MOTOR.CEVA DE GENU CAND BATI FIER PE FIER. EU M-AM GANDIT SA DAU JOS CUREAUA DE LA ALTERNATOR SI SA O PORNESC. SA VAD DACA ESTE VREO ROLA STRICATA ACOLO CARE CAUZEAZA ACEL SUNET. POATE SA-MI ZICA CINEVA DACA FAC BINE? IAR A DOUA PROBLEMA SAU ASA CRED EU CU TOATE CA UNII MECANICI MI-AU SPUS CA NU ESTE NIMIC IN NEREGULA. ESTE NORMAL CA SA TREACA ULEI DIN TURBO IN RADIATOR SI DIN RADIATOR INAPOI IN MOTOR. :censored:
 Post subject: Re: PROBLEME ALFA
PostPosted: 24 Mar 2010, 12:06
specifica ce radiator, daca e cel de apa, evident ca iti ai garnitura de chilasa fisurata sau acel schimbator de caldura ca suport al filtrului de ulei defect, daca e intercooler-ul... e normal sa fie putin ulei, pt ca vaborii de ulei ce vin din capacul de la axul cu came sunt reintrodusi in turbina, iar daca e uzata mai pierzi si pe acolo, acum depinde cat (verifica la joja)
Hmm eu zic ca nu-i suficient sa`ti repari alfa dupa ureche, dar e un inceput :) daca ai da mai multe detalii si te`ai documenta putin iti rezolvi problema si singur;oricum forumul nu-i service auto
PostPosted: 24 Mar 2010, 12:18
Gicutza Quote:
PostPosted: 24 Mar 2010, 12:27
ESTE INTERCULERUL...MI`AU SPUS MAI MULTE PERSOANE DAR MA GANDEAM CA TOTOUSI POATE ESTE ALTA PROBLEMA SI DE ACEEA M`AM CONSULTAT CU VOI ...V`AM CERUT SFATUL...IN LEGATURA CU SERVICE`UL LA NOI IN VALEA JIULUI SUNT MULTE DAR CU MECANICI NEPRICEPUTI ...VREAM SA STIU DACA PORNESC MASINA FARA CUREAUA DE LA ALTERNATOR ARE CEVA?VA MULTUMESC PT RASPUNSURI
