It is currently 09 Jan 2025, 15:58
Post new topic  Reply to topic  [ 4441 posts ]  Go to page Previous 131 32 33 34 35178 Next
 Post subject: Re: Alfa Romeo Giulia
PostPosted: 25 Jun 2015, 00:18
Si link -> https://youtu.be/zQh0JqaCAN0" onclick="window.open(this.href);return false;
PostPosted: 25 Jun 2015, 00:22
Daca ma ajuta cineva cu vanzarea Q4-lui actual, promit sa il inlocuiesc cu o Giulia tot Q4.
Deci, anyone ?
George, tu esti unul dintre cei la care ma refeream cand am adus in discutie cele cateva alfe noi...
Deci no offense, dar pana nu voi vedea prima Giulia pe prezentata pe forum discutiile despre preturi si cine o are mai mare sunt... discutii.
PostPosted: 25 Jun 2015, 00:24
Quote:
This is demonstrated by the exclusive technical solutions present on the new car, like Torque Vectoring with a double clutch to allow the rear differential to control the torque delivery to each wheel separately. In this manner, power transmission to the road is improved also in low grip conditions. So, the driving is safe and fun without ever having to run up against an invasive stability control system.
Mie treaba asta mi-a atras atentia. Un diferential cu dublu ambreiaj care sa permita transmiterea cuplului in mod independent catre fiecare roata in parte ? Poate inteleg eu altceva, dar daca le iese e ceva ce o sa puna multa lume pe ganduri.
PostPosted: 25 Jun 2015, 00:25
Car: Vauxhall Frontera
sneaker Quote:
Frânele cre-că merg :mrgreen:
PostPosted: 25 Jun 2015, 00:27
Automarket a preluat filmul cu Giulia postat pe Alfa Club
Razvan Patrascu
Alfa Romeo GTV V6 3.2 270CP
Alfa Romeo 147 1.9 JTD 101CP
PostPosted: 25 Jun 2015, 00:28
BZ-76-DIA Quote:
Deci, anyone ?
Sa stii ca am dat pe a mea sensibil mai mult decat pe o Giulietta cheala. Cu toata reducerea existenta... :lol:
Eu chiar am vorbit serios mai sus, in masura in care se vinde Q4-le TI, inlocuitoarea va fi Giulia Q4 !
PostPosted: 25 Jun 2015, 00:31
Valak Quote:
Si nu numai asta ! Uite aici :
Perfect weight
Great attention devoted engineers in developing the new Alfa Romeo Giulia the perfect distribution of the vehicle weight on front and rear axle. By using particularly lightweight components and the placement of the heavier components between the two axles, they reached a perfect ratio of 50:50.
The multilink rear suspension ensures optimum compromise between sporty driving behavior, driving pleasure and comfort. At the front a design with double wishbone suspension and semi-virtual steering axis is used, the steering is effectively decoupled from suspension and torque steer and enables a very direct interpretation of the steering. This Alfa Romeo exclusive layout ensures constant trailing at the front wheels even in fast bends with high lateral acceleration forces. The tire contact patch remains optimal under all conditions and all speed ranges. With the most direct steering in the segment can be the new Alfa Romeo Giulia moreover extremely precise control.
Innovative and exclusive technological solutions
It is the policy of the suspension engineers at Alfa Romeo to use electronic assistance systems exclusively to the thanks to optimally matched mechanism already excellent handling characteristics to refine. One example is the electronically controlled limited slip differential in the rear axle, the torque available is divided by means of a dual clutch active between right and left wheels (torque vectoring). Unlike a conventional electronic vehicle stability system, the full engine power is maintained even at low grip of the tires. The new Alfa Romeo Giulia first time also features an integrated braking system that combines the function of the electronic assistance systems to the mechanical brake assist. The results are outstanding and highly responsive brakes record-breaking short braking distances - with reduced weight of the system.
In addition to a low coefficient of drag aerodynamics is optimized by an active front spoiler with the new Alfa Romeo Giulia, which increases downforce on the front axle at high speeds and provides even better traction. The active front spoiler is also controlled from the chassis computer networks as a central control center all the electronic systems on board together.
For the Alfa Romeo Giulia exclusive vehicle dynamics control DNA retuned. You can choose between the levels "Dynamic", "Natural" and "Advanced Efficient". The mode "Advanced Efficient" gives the driver the first time the opportunity to vote all vehicle systems to the optimum use of fuel. The most powerful models also provide the stage "Racing" is available.
The interior of the new Alfa Romeo Giulia offers all passengers the highest levels of security, entertainment options, comfort and perceived quality. A characteristic feature is the consistent orientation of the cockpit to the driver. Much like in a Formula 1 racing car, the controls for key, vehicle-related systems are housed on the steering wheel. About two additional user-friendly multi-function switch, the vehicle dynamics control Alfa Romeo DNA and the infotainment system controlled.
PostPosted: 25 Jun 2015, 00:40
Ok atunci, pana apare Giulia monteaza pe a ta o navigatie stock (ca din ce imi aduc aminte e singura dotare care ii lipsea) si apoi transmite-mi un pret in privat. Eu fiind un provincial mai indoctrinat, inca consider 159 drept cea mai frumoasa berlina construita vreodata, deci ma voi bucura enorm sa o pot cumpara, tototada deschizandu-ti drumul ca pionier in giulianism pe forum. :wink:
P.S.: Si eu vorbesc foarte serios.
PostPosted: 25 Jun 2015, 00:44
BZ-76-DIA, Poate te intereseaza una rosie...
PostPosted: 25 Jun 2015, 00:48
BZ-76-DIA Quote:
Clar da, dar dupa F30, w205 si muuulte altele. Mai rar masina desenata din carbune, gen Solenza, dreapta la echer.
PostPosted: 25 Jun 2015, 00:53
toshy Quote:
Hai sa nu facem off-topic, nu zic ca nu m-ar interesa, doar ca baloshesc dupa a lui george de cand a luat-o... :evilook: Are absolut tot ce am visat eu in 159 (si eu am tinut mult la culoarea neagra ext. si combinatia de culori a masinii lui pe int.), mai putin navigatia aia pe care o monteaza el ca e baiat mare si se descurca... vedem ce iese, dau un ochi si la a ta
PostPosted: 25 Jun 2015, 00:55
Eu vad Giulia, o adevarata "pantera" :
PostPosted: 25 Jun 2015, 00:56
http://www.germancarforum.com/threads/2 ... 727/page-4" onclick="window.open(this.href);return false;
Mai jos pe threadul respectiv o sa gasiti ceva poze in care se vede cat de cat interiorul ( scaune si ceasurile de bord )
Edit : Din ce vad e destul de "plata" pe dedesupt ceea ce e super :)
Alfa Romeo 147 1.9 Jtd 115 cp
PostPosted: 25 Jun 2015, 01:53
sunt curios cand o sa vad o giulia pe vreo platforma la zalau, adusa de baieti din germania, estimez un 5 ani
si avand in vedere ca are tractiune spate, astept festul la care catalin va face cerculete cu o giulia :)
PostPosted: 25 Jun 2015, 02:35
@dand: da man, pe uichend daca nu ai program special ne vedem la un cico sa dezbatem subiectul.
Zici de Brutus... tehnic vorbind, din ce se vehiculeaza e jos palaria, no comment. La capitolul aspect, problema mea e ca la rima privire mi-a adus aminte de prea multe alte masini existente pe piata. Si nu e vorba ca le-am cautat cu lumanarea, am avut nevoie de doar 2 secunde. Pe de alta parte, proportiile sunt corecte, exact ce trebuie. Detaliile insa imi par din alt film. Si de aceea ma plasez in tabara carcotasiilor.
PostPosted: 25 Jun 2015, 03:45
Car: MiTo
A vazut cineva video-ul ce a aparut ?
Trimis de pe al meu GT-I9195 folosind Tapatalk
MiTo My2014 Sportech 1.3 JTDm 85cp
PostPosted: 25 Jun 2015, 08:24
Car: 156 seconda serie
Totusi vreau sa vad si varianta non QV.
In afara de V6, toate motorizarile vor fi turbo, nu va mai exista ceva NA?
AYRTON SENNA SEMPRE
PostPosted: 25 Jun 2015, 08:43
Eu cred/sper ca mașina se va încadra pe la 40-45k. Altfel o vor lua in mufa :)) la banii ăștia Dia, m-a alătur si eu lui George pentru una noua. Poate ne fac discount mai mare dacă luam doua :)))
Sent from my iPad using Tapatalk
PostPosted: 25 Jun 2015, 09:37
Car: GTV
Mie a inceput incet incet sa imi placa. Daca are o motorizare moderna, adica un diesel pana in 2000cmc cu o putere de peste 200cp (poate un bi-turbo similar cu cel vw), sa nu aibe directie electrica, sa fie usoara incat sa nu mai fie probleme de suspensie, o garantie standard de 5 ani incat sa fie mai mult decat la nemti si pretul sa inceapa de la 35k pentru cea mai cheala, chiar cred ca are sanse sa se vanda. Nu imi place cum arata pe rosu din ce am vazut pana acum, la formele pe care le are pe negru cred ca ar arata mai bine. Cand aveti poze cu ea neagra sa le urcati.
Sunt foarte curios ce zic "non-alfisti" despre ea, aici pe forum e subinteles ca va fi laudata indiferent de situatie.
Alfa Romeo GTV 3.0 V6
Alfa Romeo 156 2.5 V6
Alfa Romeo GTV 2.0 TS
Alfa Romeo 159 2.4 JTDm
PostPosted: 25 Jun 2015, 09:38
Ma tot uit la poze si la filmuletul (genial) de prezentare si observ din ce in ce mai multe detalii care ma fac sa fiu mandru de Giulia:
prizele din capota (sau ce or fi gaurile alea)
prizele inguste si curbate din masca frontala
cum se alungesc stopurile in lateral, complet diferit de tigania Ford sau Peugeot
tevile alea de esapament, puse in diagonala una fata de alta
aparenta generala in mers, volumele si forma sportiva si sexy
si, mai ales, acea "scobitura" alungita din usi, care porneste sau se termina in prizele laterale, stil 4C
Nu, serios, masina pare, la o prima vedere, ne originala, dar e clar ca are niste fineturi Alfa, suprapuse peste un design clasic, care sa atraga cumparatori diversi.
PostPosted: 25 Jun 2015, 09:44
Car: Alfa Romeo Brera
Prezentarea Giuliei de Marchionne
http://video.alfaromeopress.com/p/it/en ... post/30783" onclick="window.open(this.href);return false;
-Alfa Romeo Brera-
EX: Ducati Monster
EX: Renault Twingo 1.2
EX: Fiat Barchetta 1.8
Ex: Skoda Fabia 1.2 54cp
PostPosted: 25 Jun 2015, 09:56
Car: 147 1.6 120CP
Video din multe unghiuri si detalii exterioare. Chiar daca e in "macaronara", se intelege si ce zice frezatu' :lol:
https://www.youtube.com/watch?v=zQh0JqaCAN0" onclick="window.open(this.href);return false;
L.E. Se pare ca i-a lasat sa se plimbe pe langa ea, dar au tinut-o incuiata, de aici lipsa pozelor cu detalii de la interior. Maaari pisicheri italienii astia.
Buburuza (147/1,6/120 CP)
PostPosted: 25 Jun 2015, 10:06
Sunt curios daca se va reveni si la varianta QO, daca tot avem QV :naughty:
PostPosted: 25 Jun 2015, 10:29
E posibil, GT-ul de exemplu a avut si o echipare QO (pentru Japonia parca)
Depinde cum le vor folosi, din pacate toate denumirile recente sunt doar instrumente de marketing, si italienii sunt experti la asta. :)
AYRTON SENNA SEMPRE
PostPosted: 25 Jun 2015, 10:46
Car: No Alfa :(
eu vreau sa vad varianta "veloce" care cred eu o sa aiba un pret mai accesibil si o sa fie destul de sport.
Users browsing this forum: alex0corbeanca, dcmilitaru and 1 guest
