It is currently 18 Nov 2024, 11:16
Post new topic  Reply to topic  [ 2056 posts ]  Go to page Previous 113 14 15 16 1783 Next
PostPosted: 11 Apr 2010, 22:11
Buna tot eu!
Stie cineva unde pot sa cumpar scut motor de preferabil tabla? Tel : 0744 837575
Multumesc!
PostPosted: 12 Apr 2010, 08:15
Salut, are cineva un radiator de alfa 156 2.0 JTS 2003. Merci.
0742020221
My Ex: AR 156 SW, 2.0 JTS 165 CP
My Ex: Corsa 1.8 GSI 120 CP ”Bullet”
PostPosted: 12 Apr 2010, 10:51
Am nevoie si de un termostat pt aceeasi masina.
PostPosted: 12 Apr 2010, 17:27
Car: 156 1.9 mJTD
Furtun turbo superior...
PostPosted: 15 Apr 2010, 12:38
Xdye Quote:
Am nevoie tendonul care limiteaza deschiderea portierei la gt jtd - 2 bucati. Au inceput sa trosneasca urat de tot. (gabriel dima PM daca ai)
SA-MI COMUNICI TE ROG DACA SA REZOLVAT PROBLEMA DUPA CE SCHIMBI PIESA .
LA USA DREAPTA AM SI EU ACEEASI TROSNITURA DAR NU AM UMBLAT SA VAD DE LA CE E.
PostPosted: 15 Apr 2010, 14:48
DUMM Quote:
LA USA DREAPTA AM SI EU ACEEASI TROSNITURA DAR NU AM UMBLAT SA VAD DE LA CE E.[/quote]
La dreapta am si eu ...m-am uitat si e de la tendonul acela, trebuie schimbat. Daca are cineva PM va rog
Alfa GT 1.9 jtd 150cp +
PostPosted: 17 Apr 2010, 22:37
Car: Spider 916
PM . Thank you !
PostPosted: 17 Apr 2010, 23:45
Car: 159-Brera-Spider916
50 lei
PostPosted: 19 Apr 2010, 19:08
Car: 156 1.6 TS
Caut motoras stergatoare parbriz pt 156 1.6/2001.
156 1.6 TS
fosta GTV 2.0 TS
fosta 156 1.6 TS
PostPosted: 20 Apr 2010, 22:41
Motoras stergatoare parbriz 150 ron 0723138690
PostPosted: 21 Apr 2010, 13:11
Car: 156 1.6 TS
Merci mult..se pare ca am facut rost..daca nu e bun ala pe care-l iau, te sun!!
156 1.6 TS
fosta GTV 2.0 TS
fosta 156 1.6 TS
PostPosted: 23 Apr 2010, 13:48
Pentru AR 1.9 JTD 2001 81 Kw
1. cutie filtru + tubulatura
2. radiator + electroventilatoare
3. capac distributie
4. debitmetru
PostPosted: 02 May 2010, 17:17
Am nevoie de ornamentul reflectorizant din bara de pe partea dreapta la alfa 156.Ieri de 1 mai mi-au facut o bucurie baietii exact la mine in parcare.
PostPosted: 03 May 2010, 23:01
Car: 156 2.0 TS
Caut si eu , macara geam usa stanga spate ptre 156 an 2000. Care are de vanzare?
Italian Force 2.0 TS 155 CV Image
PostPosted: 03 May 2010, 23:02
Car: 156 2.0 TS
andrei4417 Quote:
Am uitat sa specific, Electrica!
PostPosted: 04 May 2010, 09:41
as avea nevoie de un maner usa fatza stanga alfa 147 2003
PostPosted: 04 May 2010, 10:34
Am nevoie de rama pentru casetofon pentru masina din semnatura!
Rama cu acel sertaras in partea de jos.
Jos e prinsa prin doua cleme si sus cu doua surubele.
Multumesc!
PostPosted: 05 May 2010, 23:24
vreau sa cumpar si eu o bara fata ar 147 2004 nfl. multumesc
rezolv probleme. ORICE problema
PostPosted: 06 May 2010, 20:51
Caut de cumparat suportul de oglinda din poza (ala care arata ca un leopard cu jigodie):
PostPosted: 07 May 2010, 00:58
Solutie : le dai jos pe ambele, le duci la sablat si la powdercoat(negru, rosu, cum vrei tu), end of problems. Forever. Te costa mai putin decat un suport din ala in stare buna.
PostPosted: 08 May 2010, 14:54
Aceeasi porcarie o am si eu pe o oglinda....
Solutia....o vopsesc odata pe luna.
Alfa 156
PostPosted: 08 May 2010, 17:02
Solutia am expus-o mai sus, nu e ca si cum e un secret de stat, trebuie doar sa fii mai .... descurcaret.
PostPosted: 08 May 2010, 22:27
Nu prea merge ce spui tu, pentru ca sint din fibra de sticla sau ceva asemanator, nu de metal. Daca le sableaza trece prin ele, iar de acoperit in cimp electrostatic iar nu cred ca merge.
Ca un DIY ar trebui sa le scot, sa le smirgheluiesc, grund de fibra de sticla, vopsea. Dar mi-e lene si ma p.. pe ea. Prefer una intreaga la second.
PostPosted: 09 May 2010, 00:53
Car: 156 2.0 JTS
Suportul de la oglinda este de aluminiu.
PostPosted: 09 May 2010, 02:00
Poti sa colantezi suportu de oglinda.
