It is currently 25 Nov 2024, 09:31
Post new topic  Reply to topic  [ 4747 posts ]  Go to page Previous 1122 123 124 125 126190 Next
PostPosted: 13 Mar 2015, 21:24
M-am lamurit, este o tigaie cum ar spune coman... Arcuri am eibach noi, amortizoarele imi faceau cu ochiul, dar ma las pagubas, defapt am sa vad dupa ce le demontez ce si cum ;)
Sent from my mobile
PostPosted: 18 Mar 2015, 10:12
Pompa de benzina de la TS se potriveste si la JTS ?
PostPosted: 18 Mar 2015, 10:32
Car: 156 seconda serie
Nu, sunt diferite.
Quote:
if the car is a petrol twin spark then they dont have a fuel filter thats changable, they have a metal gaze in the pump which is submerged in the tank so not changeable,
if its a petrol jts then they have the one in the tank, which is not changable and also one built into the high pressure pump on the side of the head, again its a gauze one and not changeable.
AYRTON SENNA SEMPRE
PostPosted: 18 Mar 2015, 14:21
Foloseste cineva navigatia Cygic pe Android in Romania sau Europe? E buna de ceva?
my fiat is fantastic:
Ex: 156 SW 1.9 JTD 16V
Ex: 159 SW 2.4 JTD Q-tronic
Ex. Jeep GC 2005 3.0 crd
A6
PostPosted: 18 Mar 2015, 15:27
Car: Mercedes C Coupe
Am un prieten care folosea aceasta aplicatie si am inteles de la el ca e ok. Singura problema ar fi ca nu poti vorbi la telefon in timp ce ai navigatia pornita, cred ca e un bug.
Eu am folosit Be-on-road dar nu-ti pot recomanda. M-a dus de fiecare data la destinatie dar lipsesc multe strazi si cel mai bine te duce daca ii dai coordonate, in cazul meu de fiecare data aveam si coordonate. Nu are problema cu vorbitul la telefon, ba chiar iti da indicatii si in timpul convorbirilor :lol:
In Germania am folosit eu Be-on-road si prietenul meu Cygic.
Mercedes C Coupe 192 HP
ex: Alfa 156 SW 2.0TS, 2000
Alfa 156 SW 2.4 JTD 20v, 2003
PostPosted: 18 Mar 2015, 17:28
ibiza Quote:
Daca vrei o navigatie buna pentru Android, care foloseste doar sateliti, ia Navigator. Am folosit-o si in strainatate fara probleme.
PostPosted: 19 Mar 2015, 00:41
Car: 156/Brera
Eu am Sygic pe iOS. Sunt multumit de el, de detalii, de cum se misca, etc. La fel si cu Navigon. Mai poti folosi aplicatia "here" de la Nokia, ce merge si in offline doar ca hartile ocupa dublu fata de alte aplicatii. Am vazut un Sygic pe android (crackuit) ce facea figuri. Eu le-am cumparat pe ambele.
ex: Alfa Brera 2,4 JTDM 20v 200+ (by ILuzoriu)
PostPosted: 19 Mar 2015, 09:23
Pentru Android recomand CoPilot, nu este gratis dar merita toti banii: 4,1 din 5 pe Google play!
PostPosted: 19 Mar 2015, 11:49
Car: 159
Cand schimb cauciucurile de iarna cu cele de vara se recomanda facuta si geometrie pe langa echilibrare?
Folosesc aceleasi jante, iar cauciucurile de iarna nu dau semne de uzura inegala.
Multumesc
PostPosted: 19 Mar 2015, 14:32
Car: 159 ti 1.9 q-tronic
Difera de la diesel la benzina si an fabricatie caseta de directie la AR 156?
Alfa Romeo 159 ti 1.9jtdm q-tronic
ex: Alfa Romeo 156 1.9jtd
Alfa Romeo 155 1.7 ts
Alfa Romeo 155 1.6 ts
PostPosted: 19 Mar 2015, 19:08
E secret?
PostPosted: 19 Mar 2015, 21:57
Tind sa cred ca sunt la fel... Nu ar avea de ce sa fie diferite. Caseta de directie este independenta de motor si cutie, deci nu vad de ce ar fi diferită între benzina si diesel.
PostPosted: 19 Mar 2015, 22:08
Hai ca il rog pe mecanic sa se uite maine daca e vreo diferenta. Are in curte un 2.0TS, un 1.6 TS si un 2.4 JTD.
PostPosted: 20 Mar 2015, 16:28
Car: Alfa 75, 2.0 TS LE
Aveti idee care sunt costurile pentru obtinerea si programarea unei chei pt 156 din 2006 in situatia in care nu am nici un fel de cod?
ALFA 75, 2.0 TS, ASN
CROSSWAGON Q4 (BB)
PostPosted: 20 Mar 2015, 21:55
Prin ce este diferita pentru ca donatoarea este 2.5 iar mie-mi trebuie pentru 1.9?
PostPosted: 21 Mar 2015, 16:57
Unde se afla senzorul presune de ulei la Alfa 156 2.4 mJTD 20v?
PostPosted: 23 Mar 2015, 02:03
Up! :D Intreb pentru ca imi apare eroarea cu "Low engine oil Pressure". Eu vreun senzor defect sau poate fi cauza a altceva?
PostPosted: 23 Mar 2015, 02:42
Pe spatele motorului, pe bloc, deasupra baii de ulei. Da mereu?
Cauze mai pot fi si mal in baie, pompa ulei fucked. Eu nu as merge fara sa elimin alte cauze.
PostPosted: 23 Mar 2015, 03:36
Multumesc. Nu sunt alte cauze pentru ca am facut deja 10k(era asa de cand am cumparat masina) si nu mi-a consumat mai mult de 0.5l ulei, fum nu scoate, trage bine..
PostPosted: 27 Mar 2015, 18:41
Din lipsa de chef de googalit: Stie cineva pe deasupra daca Alfa 166 facelift (>2003) are CAN precum 147 sau e non CAN ca si 156-le ? Vreau sa operez pe cord una bucata si am nevoie de aceasta info.
PostPosted: 01 Apr 2015, 08:22
Car: 147 1.9 JTD
Salut!
Nu este chiar mica problema mea, dar am vazut ca s-a mai discutat ceva asemanator si deocamdata nu deschid un topic nou.
De ceva vreme Alfa mea 147 1.9 JTD a inceput sa manance ulei, mult. Dupa ceva timp a aparut si un fel de vajait care aparea dupa 1800 rpm si se auzea cel mai tare pe la 2700 rpm. Am fost la mecanic si mi-a spus ca turbina e de vina, ca sunetul e de la ea si doar ea poate sa manance atata ulei. Am luat o alta turbina de la dezmembrari si mi-a schimbat-o. Era totul plin de ulei in jurul turbinei, a curatat tot, dar tot imi mananca ulei.
Dinainte sa imi manance ulei imi aparea eroarea MCSF cand era in sarcina si inca imi apare. Masina a tras foarte bine si cu vechea turbina si cand apare eroarea nu se intampla nimic daca mentin acceleratia, dar daca decelerez un pic trebuie sa iau piciorul de tot de pe acceleratie, sa astept o secunda, si apoi pot sa accelerez fara probleme in continuare. Cand a inceput sa imi apara eroarea prima data am schimbat senzorul MAP, dar fara rezultate. In schimb cand am curatat EGR-ul a inceput sa apara mai rar.
Ieri am pus-o pe tester si avea urmatoarele erori:
P0404 - EGR
P0704 - Clutch signal
P0235 - Supercharging pressure - Light on
P0380 - Board relay, thermostarter or preheat. ECU.
Am mai scos si niste valori de la 2700 rpm:
Intake Air Quantity - 535.5 mg/i
Desired Intake Air Quantity - 458.4 mg/i
Boost Pressure - 1,378 mbar
Desired Boost Pressure - 2,301 mbar.
Mentionez ca masina are remap de vreo 2 ani jumate si nu am avut probleme pana sa apara cele de mai sus.
Ce ma deranjeaza cel mai tare e consumul de ulei, care sa fie cauza?
Va multumesc anticipat!
PostPosted: 01 Apr 2015, 11:26
Car: 147 1.9 JTD
Tubulatura inseamna furtunul ala cu forma ciudata de la turbina la intercooler? Era un pic crapat in zona unde se prinde colierul si i-am pus niste banda. Poate sa fie lipsa de presiune de acolo?
Am uitat sa spun ca nu scoate si nu a scos fum excesiv.
PostPosted: 01 Apr 2015, 11:49
Car: 147 1.9 JTD
A, acum stiu despre ce e vorba. Nu e nici o problema cu ele, le-am verificat...
PostPosted: 01 Apr 2015, 20:08
casetele de directie sunt la fel de la 1.6 la 2.0 - cea de 2.5 este diferita
la diesel cea de 1.9 din ce stiu este ca si cele de 1.6 - 2.0 - iar cea de 2.4 este iarasi diferita.
Am pus caseta de la 2.5 la 1.9 si pot sa spun ca nu exista diferente.
PostPosted: 01 Apr 2015, 23:49
Pentru un 147 Fl, se poate schimba volanul cu unul cu comenzi avand in vedere ca HU-ul nu e cel original? HU suporta comenzi pe volan, dar mufarea banuiesc ca este diferita. Stiu ca s-a mai discutat, dar topicurile erau despre cuplare cu HU stock. Multumesc.
