It is currently 08 Feb 2025, 12:17
Post new topic  Reply to topic  [ 1437 posts ]  Go to page Previous 122 23 24 25 2658 Next
PostPosted: 05 Jul 2014, 16:10
ma bucur foarte mult ca mai exista si oameni informati si impartasesc asta, intr adevar tehnica militara dar si cea medicala ruseasca e la ani lumina ca fiabilitate/posibilitate de mentenanta/redundanta fata de multe altele de pe pamant, au si ei bubele lor, trebuie luat ce e bun din toate.
testul cu uleiurile e cam primul de acest gen pe care il vad, corespondez cu cativa prieteni de acolo si raspunde la foarte multe intrebari despre ce se uzeaza, cat se uzeaza, in cat timp se uzeaza si sper ca lamureste niste intrebari care s au mai pus pe forum si anume ca viata unui motor in care se pune ulei cu specificatiile producatorului depinde doar de modul de exploatare si de calitatea materialelor folosite, un gunoi ramane un gunoi indiferent ce ulei o sa i torni.
PostPosted: 10 Jul 2014, 12:22
Hai ca nu sa ma scris de mult pe aici... Din dorinta de a incerca si un ulei complet sintetic, am gasit pe site-ul selenia urmatorul tip de ulei destinat motoarelor pe benzina alimentate cu LPG/GPL .
Selenia Multipower GAS 5W-40
Selenia Multipower Gas is a fully synthetic lubricant designed for petrol engines, also turbocharged, powered with methane or LPG. Its exclusive formulation improves valve protection against wear, neutralises the acid compounds formed by the combustion and keeps engine performance level.CharacteristicsSelenia Multipower Gas has a special formula that, contributes to obtain, through the blow-by fumes, the best characteristics of adhesiveness, anti-wear and cleansing at the interface between valve and valve seat. The elevated starting value of the TBN contributes to neutralise the oil acidity, avoiding the chemical aggression of the parts during the whole drain interval.
Fully synthetic lubricant.
Resistance to wear for the tappets (new special additive).
Low viscosity in order to improve the cold start.
Fuel economy.
Greater protection for modern TWC.
In force also for Euro 5 engine.
Maximum International specifications.
Specifications
SAE 5W-40
API SM
ACEA A3/B4/C3
FIAT 9.55535-T2 CONTRACTUAL TECHNICAL REFERENCE N°F922.E09
voi astia mai priceputi in ale uleiurilor, ce imi puteti spune ? Este ok pentru un motor TS? Tin sa precizez ca eu merg cu masina in 90% timp in oras si la viteze destul de reduse ( maxim 80 ). Uneori noaptea cand este liber o mai fugaresc unpic si ajung la turatii mai ridicate ( 5000-6000 ) .
Multumesc anticipat !
PostPosted: 10 Jul 2014, 17:45
foarte bun chiar.
PostPosted: 13 Jul 2014, 22:35
Car: megane diesel
am si eu 2 intrebari:
A folosit cineva vreodata un ulei 0W60? Daca da, ce marca si de unde poate fi achizitionat
Atentie nu ma refer la 5W60 sau 10W60 :scratch:
multumesc
si alta intrebare:
a folosit cineva vreodata renewable lubricants 5w40 la care ii tot face reclama pe internet acest iuliu m.?
viewtopic.php?f=29&t=6178&hilit=ce+fel+ ... &start=525" onclick="window.open(this.href);return false;
 Post subject: MOTUL si BARDAHL
PostPosted: 27 Jul 2014, 15:36
Salut!
Ce parere aveti despre produsele Motul si Bardahl?!
Stiu ca s-au facut topic-uri despre uleiuri specifice pentru AlfaRomeo, aici nu e vorba despre asta. Printre voi sunt persoane avizate sa dea un sfat cu privire la uleiul auto BUN, nu neaparat cel recomandat de producator. Prin acest topic va rog sa imi spuneti parerea voastra de spre aceste doua marci de ulei auto.
Masina mea, de 4 ani e 146, 1.6 boxer cu 76 kw din 1996. Vreau sa o pastrez, ar trebui sa ii schimb uleiul si ma gandeam sa trec la gama racing (Motul 10w40 300v sau Bardhal 10w60 XTR 39.67 Racing c60 ) pentru a proteja motorul. Selenia, Castrol si Mobil m-au dezamagit (se innegresc foarte repede si se aude zgomot metalic in primele 2000 km. Mentionez ca nu am pierderi de ulei)
Ma gandeam sa cumpar un schimb de MOTUL 300V 10W40 full sintetic dar, din auzite, de la amici cu motociclete Bardahl ar fi mai bun la testul de frictiune.
Voi ce parere aveti?
 Post subject: Re: MOTUL si BARDAHL
PostPosted: 27 Jul 2014, 15:45
stiu ca e un topic de uleiuri, ambele sant uleiuri de top, daca ai sunete ciudate la motor asta nu e din cauza uleiului , verifica reglajul culbutorilor, motoarele se uzeaza indiferent ce ulei vei pune in ele, uzura lor tine si de ulei dar mai ales de modul de exploatare si de respectarea perioadelor de service.
permite mi sa fac o gluma, cand traia bunicu acu vreo 20 de ani, i am adus o tigara kent din pachetul unui prieten de la bloc, bunicu a luat frumos kent ul i a rupt filtrul si a fumat o, "buna nepoate, buna rau"!
cu alte cuvinte nu stiu cu ce ar imbunatati viitorul motorului tau aceste doua uleiuri, dar poti incerca.
PostPosted: 27 Jul 2014, 16:11
Subiectul legat de bardahl si motul a fost mutat aici.
Nu era necesar sa deschizi un topic nou pentru intrebari care se pot incadra in aceasta sectiune.
PostPosted: 27 Jul 2014, 23:52
motorul a fost desfacut anul trecut in primavara, l-am curatat, segmentat si inlocuit garniturile. Schimburile au fost facute la 8000 km (asta de cand e masina la mine). Deci uzuri mecanice nu ar trebui sa fie (zic eu).
Multumesc!
PostPosted: 27 Jul 2014, 23:58
Scuze pentru creat topic nou unde nu trebuie, nu asta intentionam, voi fi mai atent.
Faza cu tigarile si cu bunelu am patito si eu :lol:.
PostPosted: 28 Jul 2014, 00:02
vezi ca boxerele astea au prostul obicei sa tzacane in dreptul axelor cu came, sant motoare de turatie mare si apar uzuri in dreptul axelor cu came, verifica culbutorii si axele, stiu ca se refac din cand in cand niste reglaje.
e super uleiul la care te ai gandit pentru motoare de turatie insa e si printre cele mai scumpe (10w60), in mod normal 10w40 ar trebui sa si faca treaba, daca mergi si iarna cu masina incearca un 5w50.
PostPosted: 28 Jul 2014, 20:28
Car: 156 8v '02
A încercat cineva Gulf Formula G 5w-40? Dacă nu, l-ați încerca? :mrgreen:
Are un preț foarte bun și e „vollsynthetische”.
Don't. Cut.
PostPosted: 28 Jul 2014, 21:00
eu personal nu as turna asa ceva in motorul meu.
PostPosted: 28 Jul 2014, 23:15
cristianmiu Quote:
De ce, e un producator renumit, mare experienta in motorsport, poate fi un ulei extraordinar daca ne bazam doar pe producator.
PostPosted: 28 Jul 2014, 23:31
stiti cum e asta cu producatorul renumit? ca cei de la sony sau samsung spre ex... sunt niste producatori renumiti, insa doar produsele de top sunt cele calitative.
Acum nahh... este alegerea fiecaruia ce pune in motor... eu as alege ce scrie in carte, pentru ca nu de idiot a recomandat producatorul acel ulei...
PostPosted: 28 Jul 2014, 23:55
sneaker Quote:
Daca iti este usor sa il iei merita incercat, singurul lucru ce ridica semne de intrebare este pretul, cumperi cantitatea de schimb la pretul necesarului de completat intre schimburi :)
PostPosted: 29 Jul 2014, 00:14
Car: 156 8v '02
„completat intre schimburi”? Cannot compute :mrgreen:
Don't. Cut.
PostPosted: 29 Jul 2014, 00:27
Adica dai pe 5l cat dai pe 1.5 de Selenia.
PostPosted: 29 Jul 2014, 11:30
Car: GTV 2.0 JTS
sneakerul se referea la faptul ca intre schimburi nu necesita completare de ulei ;)
Alfa Romeo 916 GTV 2.0JTS
Alfa Romeo 916 Spider 2.0TS
Alfa Romeo 159 2.4JTDm
ex: Alfa Romeo 156SW 1.9JTD
uneori fotograf
PostPosted: 29 Jul 2014, 11:59
zenzaman Quote:
Am vazut ce motorizare are, dar am vrut sa dau un exemplu de diferenta de pret si cam cat e de mare.
PostPosted: 29 Jul 2014, 23:05
Sony si Samsung nu au produse de top, au produse comerciale si nici nu vor sa aibe, produse de top au B&W, Focal, Onkio, Lowe si altii.
Alfa GTV V6 TB
Toyota Auris
1.6
Alfa 147 1.9
Fiat Fiorino
Suzuki Ignis
Dacia Solenza 4.4 V8
Tico 5.0 V12
Chrysler Voyager
Ford Siera Cosworth
PostPosted: 30 Jul 2014, 09:56
Dizzy_147 Quote:
ulei din asta nu am incercat dar eu zic ca merita :D
PostPosted: 01 Aug 2014, 16:50
Car: ARGiulietta
Ieri am schimbat prima data uleiul la Giulietta (10 800km)
Cel vechi, din fabrica, era cam obosit, incepea sa se simta ca apa intre degete.
In fine, ce ma oftica e si ca-n FR intretinerea in garantie e la oha.
Dupa ce ca n-ai voie sa vii cu uleiul tau, fiindca fiecare reprezentanta sau service autorizat are propriile ghesefturi cu firmele de ulei, nici nu se deranjeaza sa respecte specificatiile din manual (norma FIAT 9xxxx-s1). De altfel, la MultiAir 2014 se recomanda 0w30, ei pun tot 5w40, fiecare cu firma lui (igol, total, mopar-pennzoil), nici unul n-are recomandarea aia fiat. De Selenia abia dac-au auzit.
In fine, acu merge cu Q8 Formula Excel 5w40, (hidrocracat, nu "sintetic" cum zice eticheta, din petrol kuweitian, rafinat in Olanda, cu un pret ciudat de avantajos), ca asta aveau la un service autorizat, unde-am dat 77€ in loc de229€ cat voiau la reprezentanta. La banii astia, dupa 10k il schimb iar, desi pe-aici multi fac ochii mari ("de ce nu asteptati pan la 30.000!?")
Cum garantia nu prea ma lasa sa pun singur ceva de super calitate, o sa merg pe calea asta (un ulei banal, schimbat des). Macar filtrul e original. Asta e, pana-mi fac timp si curaj sa-l schimb singur.
PostPosted: 01 Aug 2014, 17:04
ar trebui sa fie ok, sigura problema e ca in viata unui motor nu prea e bine sa revii de la vascozitati mai mari la vascozitati mai mici, asta teoretic, pentru ca se va mari consumul de ulei si e posibil sa scada presiunea de ulei fata de situatia in care s ar fi folosit de la inceput acel ulei cu vascozitate mai mica, dar asta e valabil dupa un numar mare de km, ai vazut si testul rusilor, daca motorul are niste metal serios in el nu e nici o problema, calitatea materialelor este totul.
PostPosted: 01 Aug 2014, 22:40
comanr Quote:
Multumesc pentru sfat!
PostPosted: 02 Aug 2014, 00:25
Car: ARGiulietta
@ Negru: cum nu-ti consuma foarte mult ulei de obicei, incearca ceva mai fluid (mai ales la rece), gen 0w40 sau 5w40, care sa urce mai repede si sa unga mai bine axul cu came si ce mai poate tacani pe-acolo; poate 10w ala e prea "gros" si nu circula asa bine, nu vad de ce te-ai crampona de araceturile cu gradatia 10w.
Fa o-ncercare, oricum costa mai putin ca 10w60. Vascozitatea potrivita e mai importanta ca marca uleiului.
Si n-ar strica sa controlezi daca nu-s semne de uzura, cum spunea si colegul.
