It is currently 25 Nov 2024, 00:26
 Post subject: Coduri eroare OBD-II
PostPosted: 29 May 2008, 00:45
Car: VW Passat CC
le putem pune la sticky? eu le-am cautat mult timp pana am dat de ele, le-as fi gasit mai repede aici.. poate mai au si altii nevoie..
si se facu sticky :D
madkat
Complete List of ODB-II Trouble Codes
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
ex: Alfa Romeo 156 2.0 TS
 Post subject: Re: Coduri eroare OBD-II
PostPosted: 11 Nov 2010, 12:56
iata si codurile de eroare specifice pentru Fiat/Alfa Romeo
P1001 CAN line
P1003 Ext. influence on quantity
P1101 Barometer pressure
P1101 Pressure loss in the boost circuit
P1105 Altitude sensor
P1106 Boost pressure sensor
P1107 Spirl solenoid
P1108 Electric fan - assembly 1
P1109 Electric fan - assembly 2
P1110 A/C control break off
P1110 Signal disconnection A/C
P1112 Control fuel pressure
P1118 Diesel pressure control
P1121 Throttle position potentiometer 1 [signal implausible]
P1121 Throttle potentiometer track 1
P1122 Throttle position sensor [signal implausible]
P1122 Throttle potentiometer track 2
P1132 Fuel rail pressure
P1132 Sensor of catalyst temperature
P1133 Lambda 1 signal above catal.(deviated)
P1133 Oxygen sensor B1-S1
P1135 In position 3 piston
P1135 Oxygen sensor B1-S2
P1135 Preheating resistance 1 above catal.
P1138 Diesel pressure circuit
P1141 Worheiwid. 1 below
P1153 Lambda 2 signal above catal.(deviated)
P1155 Preheating resistance 2 above catal.
P1169 Voltage condition 1
P1170 Mixture ratio [Minimum lean fuel]
P1170 Voltage condition 2
P1171 Self adaptive parameter DTV
P1171 Test break off, cylinder regulating
P1171 Test interruption Testing One
P1172 Mixture 1 stength (multiplicative)
P1172 Self adaptive parameter TRA
P1173 Mixture 1 stength (additive)
P1173 Ratio mixture 1
P1173 Self adaptive parameter FRA
P1175 Mixture 2 stength (multiplicative)
P1176 Mixture 2 stength (additive)
P1177 Mixture 1 stength (multiplicative)
P1178 Mixture 2 stength (multiplicative)
P1220 Throttle position [signal implausible]
P1221 Accelerator potent. track 1
P1221 Line driven potentiometer 1 [signal implausible]
P1222 Accelerator potent. track 2
P1222 Line driven potentiometer 2 [signal implausible]
P1226 Accelerator pedal movement
P1300 Relais pre/after heating
P1300 Tonrad [run] takeover
P1300 Tooth wheel [Accomplish]
P1301 Classification injector
P1314 Vertical acc.
P1320 Synchronise Pulse/RPM
P1320 Timing/revs synchronisation
P1325 Circuit detonation value
P1325 Detonate sensor [signal implausible]
P1325 Knock measuring circuit
P1325 Knock test regulating circuit [open or short to earth]
P1326 Knock control
P1336 Torque control(request)
P1337 Torque control(comparision)
P1402 Flap
P1402 Ventol EGR throttle valve
P1403 Additional heating
P1403 Auxiliary heater
P1404 Circuit TL4226
P1408 Coolant heating circuit
P1408 Heater from heat circuit
P1421 Catalytic converter 1 temperature
P1425 Catalytic converter 2 temperature
P1429 Pressure sensor discharging
P1435 Additve addition system
P1446 Additive
P1448 Particle filter (FAP)
P1451 Intake air heater control
P1458 Water valve
P1481 Fan control
P1504 Input key
P1511 Battery voltage below sensing
P1511 Battery voltage low
P1511 Idle speed regulation potentiometer
P1512 Driver minute block
P1513 Idle speed regulator
P1514 MIL [signal implausible]
P1519 Cooler control unit
P1521 Contact voltage supply
P1529 Clutch switch
P1531 A/C compressor relay
P1531 Climate control [open circuit]
P1536 ESP system
P1555 Brake/Accelerate signal implausible
P1565 Cruise control level line
P1565 Lever cruise control Line
P1601 Cruise control switch off
P1602 A/D converter
P1602 Battery voltage
P1602 Voltage circuit
P1602 Voltage regulator
P1603 Control Unit Power Supply
P1604 Main relay
P1606 Diagnostic lamp
P1606 MIL
P1608 Coolant temperature warning lamp
P1608 Engine coolant temperature indicator
P1612 Fuel filter heater relay
P1613 Fuel contain water
P1613 Remote coding
P1614 Battery voltage sensor
P1614 Supply voltage sensor
P1620 Error in ECU gas [Error]
P1653 Camshaft position (phase) regulation
P1653 Phase variator
P1654 Control module malfunction
P1654 Modular manifold
P1655 Control module malfunction
P1664 Repeat throttle angle [over max. value]
P1671 Diesel pressure regulation
P1671 Fuel rail pressure regulator
P1672 Control module memory
P1673 Voltage condition 1
P1674 Voltage condition 2
P1680 Motorised throttle(spring)
P1681 Motorised throttle(spring)
P1682 Motorised throttle
P1683 Motorised throttle(recovery)
P1684 Motorised throttle(plausibility)
P1685 Motorised throttle(without learn)
P1686 Motorised throttle(1st idle learn)
P1686 TP adjustment self adaptive [signal implausible]
P1687 Motorised throttle(stop learn)
P1687 Throttle driven [signal implausible]
P1688 Motorised throttle(2nd idle learn)
P1689 Motorised throttle(self-compensation)
P1690 Safety cut-off
P1691 Secure breakdown
P1702 Connector lamp from A/T
P1703 Engine shut-down from aut. gearbox
P1703 Manual position switch
P1704 Auto transmission
P1704 Secondary pressure sensor
P1705 Auto transmission RPM Regulation
P1705 Connection with ABS
P1705 Control revs A/T
P1705 Reg. revs A/T
P1706 Throttle signal
P1707 Pulley check
P1708 Secondary pressure check
P1709 Chutch check
P1710 Brake Switch
P1711 Key lock solenoid
P1712 Lever Release solenoid
P1713 Neutral Signal to engine ECU
P1722 Idle Increase Signal to Engine ECU
156 2.0 jts
PostPosted: 12 Dec 2010, 14:38
Ghidul erorilor
OBD II Fault Codes Reference Guide
The Diagnostic Trouble Code numbering follows a standardized structure. All Diagnostic Trouble Codes have a letter followed by a 4-digit number (e.g. P1234).
The first letter defines the system designation:
First Letter System Designation
P Power train
C Chassis
B Body
U Network Communications systems
For EOBD, first digit defines code type
First Digit Code
0 Standard EOBD
1 Defined by vehicle manufacturer
2 Standard EOBD
3 Network Communication
Second digit defines system identification
Second Digit Meaning
0 Standard Code. Refer to generic P0 code list.
1 Fuel or Air Metering and Auxiliary Emission Controls
2 Fuel or Air Metering and Auxiliary Emission Controls
3 Ignition System or Misfire
4 Auxiliary Emission Controls
5 Speed control (Idle, vehicle and Auxiliary Inputs)
6 Trip Computer and Auxiliary Inputs
7 Transmission
8 Transmission
9 Transmission
Other Code Groups which may be read:
P10-- to P12-- Fuel and Air Metering and Auxiliary Emission Controls
P13-- Ignition System or Misfire
P14-- Auxiliary Emission Controls
P15-- Vehicle Speed, Idle Control, and Auxiliary Inputs
P16-- Computer and Auxiliary Outputs
P17-- to P19-- Transmission
P2--- SAE Controlled DTCs
P20-- to P22-- Fuel and Air Metering and Auxiliary Emission Controls
P23-- Ignition System or Misfire
P24-- to P29-- SAE Reserved
P3--- Manufacturer Controlled and SAE Reserved
P30-- to P32-- Fuel and Air Metering and Auxiliary Emission Controls
P33-- Ignition System Misfire
P34-- to P39-- SAE Reserved
PostPosted: 06 Nov 2011, 15:02
Car: Mercedes C Coupe
Vad ca nu s-a mai scris de mult aici. Am o problema in a porni o Alfa 166 2.4 JTD, 136 CP.
Imi da urmatoarea eroare : U1600 - Imobillizer : key faulty
Engine start permission : not allowed. Bineinteles, beculetul cu cheia ramane aprins.
Ma puteti ajuta? Multumesc, Andrei
Mercedes C Coupe 192 HP
ex: Alfa 156 SW 2.0TS, 2000
Alfa 156 SW 2.4 JTD 20v, 2003
PostPosted: 30 Aug 2012, 12:46
Am avut de curand nevoie sa identific niste coduri de culori pe o schema electrica si am fost surprins sa vad ca nu sunt cele standard, din engleza (sau germana, diferentele fiind minore). Asadar, iata-le:
N = Nero - Negru
B = Bianco - Alb
A = Azzurro - Bleu
M = Marrone - Maro
G = Giallo - Galben
R = Rosso - Rosu
V = Verde - Verde
H = Grigio - Gri
S = Rosa - Roz
C = Arancione - Portocaliu
Z = Viola - Violet
L = Blu - Albastru
PostPosted: 13 May 2013, 18:41
Car: ALFA 156 1.9jtd
salut! p 0380 board ......continuarea nu mai stiu exact imi poate spune cineva ce reprezinta?multumesc anticipat!
PostPosted: 13 May 2013, 18:44
CATALIN1979 Quote:
bujii/ releu teoretic.
PostPosted: 13 May 2013, 18:48
ms!am gasit toata denumirea:error P0380 - Board Relay, Thermostater or preheat. ECU.
PostPosted: 18 Jun 2013, 00:59
Car: Alfa Romeo 156 SW
Stie cineva ce trebuie facut la codul P0A00?Pls!
Elf:Alfa Romeo 33 - 1994-1995
ZAR 93200001324976
PostPosted: 18 Jun 2013, 02:24
deck_jena Quote:
Am gasit ca ar fi vorba de asta: Motor Electronics Coolant Temperature Sensor Circuit
Sursa
PostPosted: 18 Jun 2013, 16:58
tomi_alfa Quote:
Sursa
Stiu ca-i"Motor Electronics Coolant Temperature Sensor Circuit"...nu stiu cu ce se mananca si daca se schimba vreo piesa ,ceva.Cam ce piesa tre' schimbata si cum ii zice?...ca dupa mintea mea imi suna a senzorul de la termostat da'teama mi-e ca spun o prostie....ca nu vad in denumirea erorii cuvantul "thermostat".....a propos de cele de mai sus:acul la apa imi sta la 50°C(de fapt se ridica doar la forja dura) dar daca pun mana pe conducta de la expansiune ma ard...nu prea pare a 50-55°C.Am gasit ca P0A00 este "Câblage,sonde de température du liquide de refroidissement du convertisseur de tension"...ceea ce m-ar duce cu gandul la sonda de temperatura dusa...dar mai bine cer si alte pareri ca dau 42.5+25lei pe sonda si ma trezesc ca tre' sa iau si termostat-280+25 lei :bash: ...probabil in final o sa scot termostatu' si o sa-l fierb :lol: sa vad daca lucreaza bimetalul :idea: si cu asta am eliminat 280+25 lei
ZAR 93200001324976
PostPosted: 18 Jun 2013, 19:18
Daca furtunul cel gros care pleaca din termostat spre radiator e fierbinte, inseamna ca termostatul functioneaza. Ce mai ramane de testat/schimbat este senzorul de temperatura de pe acesta. Costa vreo 40-60 de lei, doar senzorul.
PostPosted: 18 Jun 2013, 19:53
tomi_alfa Quote:
Merci Tomi!!! Chiar maine iau la incins Alegria si masor temperatura conductei.Inca o data multumesc!
ZAR 93200001324976
PostPosted: 06 Feb 2014, 11:46
Car: Alfa 147 1,6 16v
Odata cu achizitionarea unui cablu de diagnoza si efectuarea unui test, am descoperit 3 coduri de eroare, coduri cu care m-am mai confruntat si in trecut dar am crezut ca voi scapa de ele odata cu inlocuirea bujiilor dar se pare ca nu. acestea sunt urmatoarele coduri: P0300-misfire/ P0301-cyl 1 ignition fail- reason signal high/ P0303-cyl 3 ignition fail-reason signal high.
Intrebare mea este, ce anume produce acest "signal high" si cum s-ar traduce asta, cumva se refera la tensiunea curentului sau e altceva? Alaturi pun si cativa parametri inregistrati, poate ca vreun coleg mai priceput imi poate face o legatura intre acesti parametri si erorile spuse mai sus.
Alfa Stelvio Q4 2.2
Alfa Spider '01
Alfa 159, 1.9jtdm,8v
Ex. Alfa 147, 1.6, 16v
PostPosted: 07 Feb 2014, 17:39
Nu ma poate ajuta nimeni cu acel "signal high" ? Astazi m-am dus sa cumpar fisele (de fapt doar "pipele" ) dar pretul m-a dezarmat, 120lei/buc. :samui:
Alfa Stelvio Q4 2.2
Alfa Spider '01
PostPosted: 03 Oct 2014, 14:24
Car: 156 2.0 TS
Ma ajuta si pe mine cineva cu aceasta eroare ? P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
mai exact unde se afla acest senzor si sub ce denumire il gasesc sa il pot cumpara, multumesc.
Spune ce vrei, spune-o cum vrei ALFA ROMEO!
ALFA ROMEO 156 2.0 Twin Spark
PostPosted: 03 Oct 2014, 16:48
Senzorul este montat pe blocul motor, pe partea din spate(spre spatele masinii) sii are o mufa maro ce se gaseste pe galeria de admisie.
Senzor gasesti pe la magazine de piese.
Alfa GT, 2.0 JTS, 166 CP
ex Alfa 156 SW 1,9 JTD 110 CP
ex Alfa 147, 1.6 TS, 105 CP
PostPosted: 03 Oct 2014, 17:08
La magazin ar trebui sa il gasesti sub denumirea de senzor de detonatie.
PostPosted: 05 Oct 2014, 23:23
Car: 156 2.0 TS
Va multumesc mult, intre timp am vorbit si cu tomy si ma ajutat. Senzorul se gaseste sub denumirea "senzor batai".
PostPosted: 01 May 2015, 12:35
Car: ARGiulietta
Sunt total tufa in domeniu, dar as vrea sa-mi pot citi singur codurile pe cele doua italiene.
Ce-mi trebuie? Un adaptor si un program pe calculator? Care program?
Ca si adaptor, asta cu Bluetooth e bun?
http://www.amazon.fr/Bluetooth-Diagnost ... ywords=obd
PostPosted: 01 May 2015, 13:17
zveroboy78 Quote:
Link Gasesti aici tot ce ai nevoie. Poti folosi si un cablu KKL cu butoane de comutare pe diferite interfete (ABS, ECU, AIRBAG etc.)
PostPosted: 01 May 2015, 13:35
Car: ARGiulietta
Multumesc mult, Tomi; se poate sterge postul meu de mai sus, e clar ca n-am cautat cum trebuie.
PostPosted: 20 Nov 2015, 23:28
Car: Alfa rome 156
Salut am si eu o eroare c1505 de la ce este are legatura cu srs sau abs ? Afla 156 1.9jtd
PostPosted: 05 Nov 2019, 01:57
La Mishto Quote:
madkat
