It is currently 31 Jan 2025, 02:29
 Post subject: Q2 / Quaife - PRO/CONS
PostPosted: 01 Jan 2013, 05:21
Car: 159-Brera-Spider916
Ca urmare a unor discutii extrem de aprinse insa intr-un topic complet gresit va invit sa va contraargumentati cat doriti privitor la aceste sisteme !
Mentionez insa ca derapajele verbale vor fi sanctionate ,daca totusi vreti sa va urati de bine in noul an aveti butonul magic de mesaj privat sau poate pentru unii dintre voi e recomandat chiar un masaj privat < destinde, relaxeaza, samd>
PostPosted: 01 Jan 2013, 16:23
Cred ca era o idee sa muti posturile si nu sa le stergi..
PostPosted: 01 Jan 2013, 16:55
Posturile am vrut sa le mut insa aproape jumatate erau insulte si atacuri .
Acum ca nu mai sunt relationate cu gta, softari si catalizatoare scoase probabil nu vor mai fi atât de interesante însă daca cineva vrea sa faca dovada cunoștințelor de mecanica, fizica, experiențe proprii cu astfel de dispozitive o poate face aici !
Sent from my GT-I9300 using Tapatalk 2
PostPosted: 01 Jan 2013, 17:09
a fost fun oricum.
nu o sa mai vin cu opiniile mele desi o sa fac cateva observatii la sfarsitul post ului , atasez o parere a cuiva care se pare ca a avut acces la informatii valoroase din lumea racing ului .
Bad weather/wet driving: Here is where I really don't like the Torsen II. My 1.6 was an all around easier car to drive in wet conditions. Much of this can be attributed to the better tires. With less power to break the tires free and more grip isn't no surprise it's easier to control the older car. The problem is the Torsen makes the ‘99 even worse than it would be with the open dif. Given the low grip of my tires, compounded by a wet road it's very easy to send the whole tail around when you don't mean to. When going around a corner with an open dif and too much gas the inside wheel will typically spin first. The power that was going to both wheels now transfers to the unloaded wheel and the whole car slows down. The outside wheel may have lost power but it didn't spin and continued to provide lateral grip to keep the tail from coming around. Because the VLSD can't transfer much torque between wheels it's not likely to move enough power to the outside wheel to break it free. With an open dif and a spinning inside rear wheel we'll get some power to the outside rear (only proportional to the torque required to spin the inside tire). With the VLSD we might get 10-15% more power to that outside wheel.
When I take the same turn with the Torsen that outside wheel gets most of the power the inside wheel didn't use thus we have enough power to break both wheels free. That's great for drifting but not as good for taking a turn in the rain. I've found that I must be much more careful with throttle application when taking turns in the wet.
If you are going to put sticky tires on the car or you are an experienced driver, I would still prefer the Torsen. If nothing else the tail out ability of my ‘99 is in large part due to that dif. If you are giving a Miata to your 16 year old first time diver, I would go open or VLSD. If you are driving in snow and ice, again I would prefer the VLSD. Of course unless you are choosing between a ‘93 or ‘94 you really don't have a VLSD vs Torsen choice, it's just LSD or open. Again, for the inexperienced driver, I would give them open. Generally I can't think of any time the Torsen will add much safety (as opposed to performance) but I can think of times it will get you in trouble.
Side note: Before I bought my ‘99 I was talking to an engineer/machinist who used to make Torsen I difs for racecars. This guy is very knowledgeable and used to work with the Indy car teams back when they were running Torsens. He told me a couple of interesting things.
1. Torsen II's aren't really torque sensing difs. The Torsen II is basically a Quaife dif. The Torsen I dif is truly a torque sensing unit. The loads at the wheels determine its biasing. The Torsen II locks more based in input torque rather than torque at the wheels. In this regard it's like a ramp based clutch pack dif without the adjustability. While he was fond of the Torsen I for racing applications he did not like the Torsen II's for racing.
As for the name, Torsen II, the company that owns the rights to the Torsen name added it to a Quaife type dif. The original Torsens were rather expensive to make. The Quaife dif was much cheaper but it didn't have the strong name recognition of the Torsen I. The solution was to name it Torsen II. It still has worm gears but the operating principle is different than the Torsen I.
2. Torsen do where out and they are sensitive to oil types. While the Torsen I relies on worm gears to operate it also relies on internal friction to function properly. Because of the steep ramp angles on the worm gears small amounts of wear can alter the bias of the dif. Additionally, changes in the dif oil will also alter the bias ratio. He specifically mentioned an Indy car example from 15 years ago when the manufacture of the dif oil changed their formula without telling anyone. The change in dif oil actually caused a change in the handling of the cars because of the difference in friction in the dif.
Unfortunately all of this Torsen information is second hand so if it doesn't agree with what you have heard I can't debate it. I can only say what I remember the guy telling me and hope nothing got lost in the translation :)
extras din: http://forum.miata.net/vb/archive/index ... 37943.html" onclick="window.open(this.href);return false;
dupa cum o sa vedeti este vorba de o instalare pe tractiune spate , intradevar la o instalare pe fata lucrurile nu stau atat de dramatic , dar interesant postul deorece se vorbeste despre acest diferential de tip torsen 2 adica torsen B adica Quaife .
Q2 de pe alfa romeo este un diferential torsen 2/quaife.
nu ma intelegeti gresit consider torsenul un upgrade serios dar pretentios.
o alta problema ar fi compatibilitatea cu ASR despre care voi incerca sa mai postez mai incolo ,am ceva material despre asta.
PostPosted: 01 Jan 2013, 18:36
Vad ca ai postat si tu la sfarsit, chiar ma pregateam sa-ti scriu ca acolo e vorba de tractiune spate.
Cat despre compatibilitatea cu ASRul, e simplu: ASR off!
Sent from my Alfa Romeo
PostPosted: 01 Jan 2013, 18:49
Instalarea unui sistem care anuleaza alt sistem nu este de dorit pentru toata lumea.
Din acest motiv e bine ca userii ce doresc acest Q2 sa stie dinainte niste lucruri , sa isi formeze o opinie corecta inainta sa cheltuie niste banuti.
PostPosted: 02 Jan 2013, 19:38
http://www.jtekt.co.jp/e/products/drive03.html" onclick="window.open(this.href);return false;
tipuri de diferentiale torsen , produse de firma japoneza jtekt.
problema cu asr ul e ca sistemul ASR (anti slip) interfereaza cu diferentialul de tip torsen si prin activarea sistemului se anuleaza intr-o mare parte functia pe care o da diferentialul , practic el franeaza roata care tinde sa patineze si diferentialul nu mai poate transfera cuplul catre cealalta roata.
datorita faptului ca ASR este "default on" trebuie instalat un dispozitiv de deactivare a ASR ului ca sa nu trebuiasca mereu sa dai off din buton.
daca mergi ponderat nu e nevoie sa deactivezi asr ,da nici de q2 nu ai nevoie...
PostPosted: 02 Jan 2013, 20:53
"Once you realise you can put your foot down and it'll pull you round rather than inducing understeer, it's quite something. But be careful in the wet - I was sliding before I'd even really realised I was. "
http://uk-mkivs.net/forums/p/494011/3397361.aspx" onclick="window.open(this.href);return false;
am atasat si alte pareri ale utilizatorilor de quaife pe FWD.
ideea e simpla : daca de obicei duci catelul la plimbare cu masina sau mergi cu parintii in masina nu o sa simti nimic rau dar in conditii de aderenta scazuta trebuie sa fii atent daca esti genul agresiv.
din ce am reusit pana acum sa citesc si din experienta mea cu un diferential de tipul acesta va pot spune ca:
-e un upgrade genial atat pentru RWD cat si pentru FWD , uneori mai solid decat diferentialul original
-de fiecare data cand dai masina unui prieten e bine sa i spui ca ai diferential torsen si sa mearga atent daca e ud sau gheata
-daca inveti sa mergi cu noul diferential , o sa ti placa si niciodata nu vrei un diferential normal
-pe timp de iarna te ajuta foarte mult dar asa cum te ajuta te si tranteste , atentie la suprafetele care alterneaza gen asfalt uscat cu gheata lucioasa sau asfalt umed cu asfalt inghetat.
-e bine sa schimbi uleiul la cutie/diferential ceva mai des ( eu il schimb la 30k)
-pentru cei care doresc sa il monteze in puntea spate(singur separat) recomand ulei de tip 75W140
-pentru cei care il pun pe fata 75w90 GL4(in cutie)
in tarile cu apa calda e musai sa il declari cand asiguri masina , daca ti l gasesc dupa nu iti mai da nimeni nici un ban deoarece acest tip de diferential cu alunecare limitata schimba modul in care se manevreaza o masina si deci modifica specificatiile producatorului.
in romania probabil ca nu o sa fie cu nimeni nici o problema , aici oricine poate tavali pe oricine si sa dea vina pe ghinion...
asa ca sfatul meu , mai multa atentie chiar daca "Q2 urile se misca biniditat :)" si chiar daca acest sfat vine de la cineva care inca mai invata(inca da in gropi).
PostPosted: 02 Jan 2013, 22:47
Acu o dai la intors? In posturile anterioare ziceai cam altceva...
PostPosted: 02 Jan 2013, 23:01
pai am zis ca e scump si e scump
am zis ca trebuie mai mare atentie iarna
am zis ca uleiul se schimba mai des din cauza frecarii suplimentare in diferential
si ca il consider un upgrade pentru un fwd , nu l as face insa pe un daily driver puternic(250 cp) cu FWD decat cu ideea ca fac un compromis care daca mi l asum e ok.
PostPosted: 02 Jan 2013, 23:59
Daca tot ai facut atata research puteai afla ca este un must have la GTA uri , diferentialul stock nu tine prea bine odata cu trecerea timpului si bubuie cutia.
Iar daca ar fi provocat atatea neplaceri ca cele expuse de tine ,mai mult ca sigur am fi aflat si noi de macar cateva masini rasturnate in sant, scapate de sub control etc..
Iar ideea ta ca un daily driver daca are 250 cai este si condus la limita e un pic exagerata ; crezi ca cei care au astfel de masini traiesc exclusiv ca sa le scartaie rotile si sa le puna pe lat .. te anunt ca poti face si cu o masina de 100 cp acelasi lucru < sa o scapi in sant >
PostPosted: 03 Jan 2013, 00:48
la platforma 156/147 ASR nu franeaza nici o roata, doar taie gazul, deci ASR nu prea are cum sa interfereze cu Q2.
din cate stiu Q2 de la alfa, montat pe 47 (varianta de echipare Q2 si Ducasti Corse) si pe GT (varianta de echipare Q2) nu blocheaza 100% pentru ca ar dauna grav comportamentului si integritatii masinii.
si simplu fapt ca alfa romeo a montat acest sistem pe niste masini ce sunt utilizate de soferi amatori denota ca un astfel de sistem nu poate fi daunator. poate fi cel mult ca aghiasma, nici bine dar nici rau sa nu faca. insa din diversele filmulete de prezentare ale firmei mama, si din review-urile utilizatorilor se pare ca de fapt face bine compotamentului masinii.
despre quaife nu stiu ce sa zic, n-am cunostinte despre el
PostPosted: 03 Jan 2013, 01:13
Eu zic altceva: mersul pe jos e cel mai sigur. Si este si sanatos!
PostPosted: 03 Jan 2013, 14:43
@yux
pentru a avea puntea fata intr-o alunecare continua despre care se vorbeste nu este nevoie de 100% lock.
fenomenul este urmatorul :
pe viraj ,in conditii de aderenta mica ,una din roti incepe sa se roteasca in gol si pierde aderenta.in acel moment putinul cuplu existent pe acea roata este transferat rotii opuse . daca acest cuplu suplimentar rupe aderenta si pe roata opusa atunci ai 2 roti care se invart in gol ,la viteze diferite ,masina nu mai are aderenata laterala suficienta si fata devine incontrolabila , fapt care nu se intampla la un diferential open deoarece roata care nu se invarte ,care practic nu ofera inaintare , ofera aderenta laterala si desi e posibil sa inaintezi greu sau sa nu inaintezi ramai cu ceva control asupra masinii.
in conditii de gheata pentru a avea acest efect de blocare e de ajuns un procent mic de genul; 30% lock
in finalul postului o sa prezint o bijuterie , o idee noua , a unei minti stralucite , un diferential care poate asigura 100% lock fara blocare externa , un diferential autoblocant cu procent de 100% , ceva absolut inedit , folosit pentru off road mai mult.
@gabi
tinand cont de cele spuse de tine , datele se schimba, inlocuirea diferentialului original fiind o chestie destul de urgenta in acest caz ,pentru a nu se intampla ceva nasol.
Ar fi foarte interesant daca ai putea sa iti comanzi un diferential de tip TORSEN 1 care spre deosebire de Q2 care este un TORSEN 2 , tinde sa transfere cuplul bazat mai mult pe aderenta(cuplul) dintre roti si mai putin bazat pe cuplul transmis de catre motor catre diferential , practic torsen 1 este o adevarata unitate de tip "TORque SENsing" , torsenul 2 fiind o varianta mai ieftina si mai putin elaborata a primului tip de torsen.
torsenurile 1 pe audi puteau gestiona puteri de 400hp+ fara modificari ale transmisiei.
Bineinteles costurile primeaza si pana la urma tu esti cel care decide ce va face si cum va face sa fie cel mai bine pentru masinuta ta superba de altfel.
aceste diferentiale de tip torsen 2 in momentul in care le simti ca au blocat si ca se intampla acel fenomen ciudat trebuie controlate doar din acceleratie adica trebuie sa ridici piciorul de pe acceleratie , nu trebuie franat , franand e mare greseala, si totul va reintra relativ repede in normal.
doresc la toata lumea , la toti alfistii sa nu li se intample absolut nimic rau niciodata la volan deoarece accidentele grave distrug vietile celor care se duc si pe cele ale celor care raman.
personal am avut pana acum toate cele 3 tipuri de torsen , 2 din ele le am si acum pe masini si am invatat singur incet incet cum se conduc genul asta de masini.
despre uzura:
la un torsen uzat, creste toleranta intre pinioanele melcate , actiunea de blocare si de transfer de cuplu efectuandu- se mai brutal , nu asa frumos dozata ca la inceput , datorita jocului intre danturile pe care se transfera cuplul.
cutia de la Q4 are magnetel pe busonul de golire , si banuiesc ca si in cutie e un magnetel , am vazut asta la mai multi producatori , pentru ca eventualele pilituri metalice sa fie capturate , sa nu produca damage suplimentar.
inainte sa inchei discutia despre Torsen , as vrea sa stiti ca nu mistourile deranjeaza , ele chiar ne destind , nu insultele , ele fac bine oarecum compozitorilor lor , atitudinea de "sheep" ,puterea slaba de imaginatie si parerile unora care nu au si nici nu au avut torsen pe masina lasa un gust amar uneori.
in final ca sa ne destindem , va vorbesc despre un diferential inventat in Rusia de un inginer, o minte absolut geniala
principiul se bazeaza pe un sirag de bile aflate in continua miscare prin diferential. inmomentul cand o roata este in aer adica are zero aderenta , siragul de bile se opreste si blocheaza 100% diferentialul .diferentialul se numeste DAK.
enjoy and be open mided!
http://www.youtube.com/watch?v=X1d7527S ... e=youtu.be" onclick="window.open(this.href);return false;
http://www.dak4x4.com/produkt/303092532" onclick="window.open(this.href);return false; use google translate
PostPosted: 03 Jan 2013, 18:56
http://www.youtube.com/watch?v=Xb6ri5qMG2I" onclick="window.open(this.href);return false;
dak in winter
PostPosted: 03 Jan 2013, 23:26
Sa fim seriosi, tre sa conduci ca un taliban sa ai parte de comportamentul descris mai sus. Extrapoland, si cu Q4 poti sa derapezi, hai sa nu ne cumparam o integrala ca poate sa ne omoare :roll:
Singurul aspect in privinta caruia ai oarescare dreptate este sistemul ASR, care, intr-adevar, e posibil sa fie diferit calibrat pe modelele ce vin cu Q2 de fabrica. Dar si acolo exagerezi, nu-i ca si cum Q2ul nu lucreaza deloc.. Intr-adevar, nu e la fel de eficient, dar pentru condusul de zi cu zi e suficient, iar cand vrei raliu, ASR off :wink:
PostPosted: 04 Jan 2013, 09:33
Ai dreptate cu integrala.vad destule accidente iarna facute cu 4x4 .poate si increderea prea mare in masina dauneaza .
cat despre exagerat asa este , dar doar asa poti vedea ce si cum.accidentele de obicei se intampla cand ceva acolo e exagerat.un drum exagerat de alunecos, o viteza exagerata, etc.
PostPosted: 04 Jan 2013, 11:12
In mare Q2-ul a fost gandit astfel incat sa-ti transfere o parte din cuplu catre roate din interiorul virajului astfel incat sa "traga" masina spre acelasi interior al virajului, diminuandu-se comportamentul subvirator. Probabil ca in acelasi spirit lucreaza toate LSD-urile montate pe masinile cu tractiune fata.
Filmul de prezentare Alfa Romeo.
Personal vad doar imbunatatiri in bine in ceea ce priveste comportamentul.
PostPosted: 04 Jan 2013, 15:10
yux , tu ai inteles faptul ca e vorba de transfer de cuplu intre rotile motoare.
ce tu nu ai inteles fiindca nimeni nu ti a explicat este faptul ca la Q2 in viraj nu are sens sa transferi cuplu spre roata fara aderenta , adica cea din interiorul virajului deoarece aia o sa se invarta in gol asa ca tre sa intelegi ca diferentialul transfera cuplul catre roata cu aderenta mai mare , in cazul de fata catre cea din exteriorul virajului si asfel masina nu mai pierde viteza .
e foarte bine ca ai pus problema asta , e bine sa dezbatem problem de genul asta.
tocmai din acest motiv caracterul subvirator este redus pe uscat dar se mareste pe suprafete alunecoase mai mult decat in cazul folosirii unui diferential clasic.
in principiu , la tractiune fata toate lucrurile sant in gama "safe" atat timp cat macar una din roti nu a rupt aderenta.
multi care au torsen pe fata nu au fortat masina iarna sau nu au mers pe gheata mai tare , cu alte cuvinte au folosit creierul ceea ce ma bucura.
problema e ca atunci cand apar in ecuatie motoare foarte puternice , greutati reduse pe axa fata datorate diferentelor de nivel si descarcarii axelor , shit can happen...
off topic:
e o alfa la noi in gl neagra un 156fl cu yux la numar e a ta sau a fost a ta? :D
PostPosted: 04 Jan 2013, 15:33
comanr Quote:
... Q2 in viraj nu are sens sa transferi cuplu spre roata fara aderenta , adica cea din interiorul virajului deoarece aia o sa se invarta in gol asa ca tre sa intelegi ca diferentialul transfera cuplul catre roata cu aderenta mai mare , in cazul de fata catre cea din exteriorul virajului ...
da, corect, ai dreptate. e si logic ce zici deoarece un diferential liber transmite catre roata cu cea mai mica aderenta (cazul cu o roata pe gheata si una pe asfalt uscat, iar in cazul de fata rolul rotii pe gheata este luat de roata de la interior, descarcata si deci cu aderenta mai mica)
offtopic: n-am nici o legatura cu masina respectiva, e doar o coincidenta.
PostPosted: 10 Jan 2013, 02:31
http://www.youtube.com/watch?feature=pl ... TdHQZohOZA#" onclick="window.open(this.href);return false;!
Apropo de discutia initiala: ia vedeti ce spune baiatul ala despre diferentialul montat in puntea fata chiar la sfarsitul filmuletului :wink:
PostPosted: 10 Jan 2013, 09:28
Din punctul meu de vedere ambele masini au o comportare dezastru pe ud, dupa cum se vede.
PostPosted: 10 Jan 2013, 09:39
Diferenta de timpi denota faptul ca nu sunt la fel de "dezastruase". Cea cu LSD s-a descurcat mai bine.
Notiunea de "dezastruos" e relativa. Dar nu vreau sa dezvolt pentru ca o dam in offtopic si nu ar fi frumos.
PostPosted: 10 Jan 2013, 09:46
Da am vazut ca astra statea mai bine.ar fi interesant pe gheata cum merg.
PostPosted: 10 Jan 2013, 10:14
http://www.youtube.com/watch?feature=pl ... TdHQZohOZA#!
It's a Lamborghini in the middle of the track , fuckyng hell :))
