It is currently 22 Sep 2024, 11:43
Post new topic  Reply to topic  [ 317 posts ]  Go to page Previous 1 2 3 4 513 Next
PostPosted: 02 Feb 2010, 05:06
baiatu' ala are masina modificata la greu si e un pic sarit de pe fix.
are injectie de apa cu metalnol, are o multime de alte chestii modificate... nu a scos cifrele alea doar din chip + dpf deletion, dar cu 670nm eu nu ii prevad viata lunga...
PostPosted: 03 Feb 2010, 13:23
Injectia de apa+metanol nu face o diferenta asa de mare.
Modificarile suplimentare sunt specificate la inceputul topicului.
Quote:
*DPF Delete:
This consists of an ecu software re-write and installation of a new center piece exhaust.
*EGR Dissable (optional):
Having seen the state the intake manifold can get into with soot from exhaust gas recirculation, and this causing sticking swirl valves, jammed egr valves, even valve guide ware, I was only too pleased to have this dissabled.
Oricum, se spunea ca nu stiu sa faca motoare mai noi, gresit. :)
PostPosted: 03 Feb 2010, 16:15
http://www.alfaowner.com/Forum/alfa-159 ... fixed.html" onclick="window.open(this.href);return false;
http://www.alfaowner.com/Forum/tuning-a ... ost2914938" onclick="window.open(this.href);return false;
http://www.alfaowner.com/Forum/tuning-a ... ost3179136" onclick="window.open(this.href);return false;
http://www.alfaowner.com/Forum/alfa-159 ... ost3168455" onclick="window.open(this.href);return false;
Cateva surse si pareri ale alora din uk despre alfatuner si/sau ahm.
PostPosted: 04 Feb 2010, 22:42
Guys, ma gandesc, ma documentez, m-as baga si eu :scratch:
AR 159 2.4 JTD negru
PostPosted: 05 Feb 2010, 01:59
Ok, pana la sfarsitul saptamanii viitoare trebuie sa dau lista finala.
Daca apar modificari in lista, pana atunci va rog sa se anunte.
PostPosted: 07 Feb 2010, 14:52
ma bag si eu.
2.4 jtdm model 2008
ideea e ca nu fie in weekendul19-21 martie cand sunt sigur plecat
PostPosted: 07 Feb 2010, 20:23
Si eu as fi interesat! 2.4 jtd 2006. Insa stabiliti data ,sa nu ne facem program! sau se ne eliberam programul!
159 2.4 neagra
ex 147 1.6T.S. 120CP
PostPosted: 07 Feb 2010, 20:31
Ok, o sa facem lista finala iar dupa va fi nevoie de un avans pentru biletele de avion, cazare etc.
Mai tarziu o sa posteze georgeg contul unde trebuie pusi banii, de asemenea si suma.
1. seth - Alfa 156 2.0 JTS
2. toshy - Alfa 159 2.4 JTDm q4 my 2008
3. georgeg - Alfa 159 2.4 jtdm Q4
4. soso - Alfa 159 3.2 Q-tronic Q4 2007 (daca nu este weekendul 19-21 martie)
5. scociu - Alfa 156 2.0 JTS
6. alexx - Brera 2.4 JTDm my 2008
7. ahara-2.4 JTDm my 2008-Brera/159?
8. RaduAlfa-2.4 JTD-te rog sa spui ce masina mai exact
9. Mike-?
PostPosted: 07 Feb 2010, 21:24
scuze uitesem sa mentionez, 159 2.4 2006 FWD
159 2.4 neagra
PostPosted: 07 Feb 2010, 21:27
7. ahara-2.4 JTDm my 2008-159 2.4 jtdm q4
8. RaduAlfa-2.4 JTDM - varianta de 200cp
9. Mike-AR 159 2.4 jtdm varianta de 200cp
Daca s-au strecurat greseli in lista va rog sa le semnalati pentru a le corecta.
Legat de ce spunea seth despre conturi si bani treaba sta cam in felul urmator:lista ramane deschisa pana in data de 15.02.2010 cand se va inchide pentru a fi transmisa mai departe catre Gus.De aceea doar pana la acea data pot interveni modifica/adaugari/renuntari din partea oricui doreste.Dupa ce trimitem lista lui Gus vom obtine preturile finale pentru fiecare masina in parte.Ar fi bine ca pana sa ajunga lista la el fiecare sa specifice ce doreste sa faca la masina, mai ales in cazul celor cu motoare diesel si dpf(soft simplu sau soft cu eliminarea dpf-ului fizic+ anularea egr-ului si rescrierea integrala a softului de regenerari).Dupa ce vom primi preturile finale am zis ca toti cei confirmati sa incercam sa strangem un avans intr-un cont, undeva la 150 euro, bani ce se vor folosi pentru achitarea biletelor de avion pentru Gus +/- Adie (daca va fi nevoie sa vina si el) si cazare pe durata sederii.M-am gandit la acest avans pentru a avea si o garantie ca atunci cand vine momentul nu se sparge gasca si raman 2-3 oameni care sa cada aiurea fata de Gus.Plus ca achitand astfel va fi si ceva mai usor de suportat costul, practic fiind impartit in transe.
Costurile de cazare +transport cred ca vor fi undeva la 200 si putin euro biletele de avion pentru 2 persoane dus-intors si vreo 100 euro cazare.Restul de bani din avansul dat de fiecare va fi pastrat in cont iar la final se va completa de fiecare cu suma necesara(din totalul constului de tuning al masinii se va scadea avansul dat de fiecare).
Asa am gandit eu problema, nu inseamna ca e cel mai bun mod sau ca e ceva ce nu se poate modifica.Chiar as aprecia daca ar scrie fiecare cam unde si cum putem sa modificam cele scrise mai sus in ideea de a fi cat mai ok pentru toata lumea.Sper ca m-am facut destul de bine inteles si, la sfarsit, toti cei care vor opta pentru remapare sa fie cat se poate de multumiti de rezultat si procedura.
P.S. Ca perioada, dat fiind ca am vazut ca si soso si ahara nu pot in w/e 19-21 martie, sa ramana fie pentru 27-28 martie fie 3-4 aprilie.
PostPosted: 07 Feb 2010, 22:01
3-4 aprilie?
159 2.4 neagra
PostPosted: 07 Feb 2010, 22:42
Toni Quote:
seth: Foarte interesant! 280Bhp doar din soft sau mai avea si alte modificari?
Consum de 6l/100km (~43mpg) n-a vazut 159le meu :) 7.7 cel mai mic consum
georgeg: cred ca ar fi util pentru toata lumea daca ai posta aici link-urile. Daca nu, trimite pm te rog. Thx!
da este foarte interesant dar e real .cu o buna remapare si cu eliminarea filtrului de particule +eliminare egr tot din soft poti ajunge la aceste rezultate .experimentat cu un grup de ingineri italieni personal .a fost un experiment cu rezultate de necrezut masina nu a plecat de pe lo ci a decolat .
PostPosted: 07 Feb 2010, 22:50
@stefantun : Ne bucuram ca esti de acord cu noi, daca vrei sa completezi informatiile deja prezentate esti binevenit, daca insa iar vrei sa iti faci reclama ca si atunci cand ai postat de pe userul celalalt mai bine renunta.
PostPosted: 07 Feb 2010, 23:00
deci ma bucur daca va bucurati si voi .am facut reclama pentru ca nu am stiut ca nu am voie .dar nu o sa mai fac .daca pot sa va ajut o sa fac cu placere privin faptul ca lucrez in sectorul asta de 11 anisori ciar si va raspund cu drag la orice intrebare de remapare s-au alte probleme s-au daca aveti nevoie de documentatie .cu placere
Este ultima oara cand intri pe un topic si discuti offtopic sau faci publicitate mascata serviciilor tale sau dai linkuri catre siteuri , iti promit ca la prima abatere o sa am grija ca ip ul , ip-urile de pe care incerci sa te loghezi cu acest user sau cu altul vor fi blocate.
Gabrieldima
PostPosted: 07 Feb 2010, 23:08
Cu atat mai bine cu cat ai posibilitatea de a ajuta colegii de pe forum si chiar a dezvolta un business pe forum e bine sa citesti regulamentul si, daca esti de acord cu conditiile existente, sa deschizi un topic dedicat in aria Oferte extinse de la Publicitate unde lumea sa afle mai mult si sa beneficieze de experienta ta, contracost bineinteles daca doresti.Nu vreau sa crezi ca am ceva personal cu tine, vreau doar sa fie intelegere pentru anumite reguli si respect intre colegi.
PostPosted: 07 Feb 2010, 23:39
ok bine sunt de acord
PostPosted: 08 Feb 2010, 02:04
Bai pe mine ma uitati? ... bine ca "vazui" topicul :fuck:
Alfeo 2,4 Jtdm 200 Hp
Alfeo / Alfa Romeo 159 2,4Jtdm 200Hp & ElNino / Alfa Romeo 147 TS 1,6 105 Hp
PostPosted: 08 Feb 2010, 04:07
@georgeg & seth
Da, ma bag, 159 jtd 2.4 200 cp, 2005, insa nu m-am decis pe care varianta sa merg. Thx.
PostPosted: 08 Feb 2010, 10:15
Update
10. edyus - Alfeo 159 2,4 Jtdm 200 Hp
PostPosted: 08 Feb 2010, 11:08
RaduAlfa Quote:
3-4 aprilie?
4-5 Aprilie sunt sarbatorile de Paste. 27-28 Martie probabil ar fi mai bine.
PostPosted: 08 Feb 2010, 11:14
Good to know, atunci vom incerca sa programam totul pentru ultimul w/e din martie, 27-28.
PostPosted: 08 Feb 2010, 19:52
Eu am sa ma limitez la resoftare, fara eliminare dpf-ului!
159 2.4 neagra
PostPosted: 09 Feb 2010, 12:16
ma inscriu si eu cu un 147, 1.6 ts pentru un soft performance!
Sex, Drugs and Rock n'Roll!
Alfa Romeo 147 120Hp Albastru
Alfa Romeo 147 120Hp Negru
Alfa Romeo 159 150Hp Negru
ex:
Fiat Punto - 63Hp - Alb
Rover - 140Hp - Green Racing
PostPosted: 09 Feb 2010, 12:56
Update
11. TheSelectOne - Alfa 147 1.6 ts - soft performance
@theselectone : Zi-mi te rog daca ai cumva ceva modificat la motor, sper sa nu gresesc, parca stiam ca ai axele schimbate.Intreb pentru a putea transmite informatiile cat mai complete catre Alfatuner.Mersi frumos.
Din ce vad incepem sa ne adunam cativa, e bine, se prefigureaza a fi un eveniment reusit pentru ambele parti. :D
PostPosted: 09 Feb 2010, 13:03
Car: Alfa 33 16v QV P4
Softeaza si 33-uri ? Ma cam bate gandul in acest caz.. dar nu ma pot inscrie pentru ca nu sunt sigur ca voi putea. itnrebarea daca softeaza si 33 ramane:P
