It is currently 23 May 2024, 17:48
PostPosted: 26 May 2023, 13:09
Car: Alfa Romeo Giulietta
Salutare!
Care este perioada de mentenanta a cutiei?
Multumesc!
PostPosted: 27 May 2023, 12:35
Car: Stelvio
Conform ZF -120-150 k km pentru primul schimb, apoi la interval de 80-100k km. Cutia e destul de rezistenta. La schimbul gravitational se schimba aproximativ 6l din total(parca 10l), deci e o improspatare a uleiului.
PostPosted: 12 Jan 2024, 13:13
Car: Stelvio 2.0 (949)
O informatie pe care o consider utila si de luat in considerare este pe site-ul ZF:
https://aftermarket.zf.com/us/aftermark ... ubricants/
5. Maintenance recommendations ZF automatic transmissions
5-, 6-, 8- and 9-speed as well as 4HP20 automatic transmissions:
ZF 5-, 6-, 8- and 9-speed as well as the ZF 4HP20 automatic transmissions are filled maintenance-free with specially developed
semi-synthetic ATF oils. However, due to the many factors influencing the service life of transmissions in individual operation, ZF
recommends an oil change after 150,000 km for its transmissions. In operating conditions with high temperatures and loads, or
with unknown vehicle use in the past, it can make sense to change the transmission oil at shorter intervals.
In each case, only released ATF oil may be used for oil changes. And oil changes must be performed in accordance with the
relevant specifications. The exception is the ZF 5HP18 automatic transmission which must be filled differently depending on the
version.
