It is currently 04 Jun 2024, 17:12
Post new topic  Reply to topic  [ 1 post ]
PostPosted: 08 Feb 2020, 04:56
Car: Alfa Romeo GT jtd
nu stiu daca a mai fost postat..sper sa fie util...
.prin cautarile mele am gasit acest diferential care se poate pune pe multe cutii de benzinare.chiar si pe cutia de 1.9 jtd 105 cai.
Forget about the one-wheel spin! With our Progressive LSD Conversion set, you will no longer suffer from losing grip!
The set is mounted on your standard differential transforming it into a clutch-type 2-way limited slip differential.
No more one-wheel spin on start, and sloppy turns around the corner. With this conversion set, you will gain the true performance of a proper limited slip differential.
Fitment:
Alfa Romeo 145/146 1.4 TS 90HP
Alfa Romeo 145/146/147 1.6 TS 105/120HP
Alfa Romeo 145/146 1.8 16V TS 144HP
Alfa Romeo 145/146/147 QV 2.0 16V TS 150/155HP
Alfa Romeo 145/146/147 1.9 JTD 100/105HP
Alfa Romeo 155 1.7 TS 116HP
Alfa Romeo 155/156 1.8 TS 129/140HP
Alfa Romeo 155/156 2.0 (J)TS 144/150HP
Alfa Romeo 155 1.9 TD 90HP
Alfa Romeo Spider 1.8 TS 144HP
Alfa Romeo Spider 2.0 (J)TS 150/166HP
Alfa Romeo GTV 1.8 TS 144HP
Alfa Romeo GTV 2.0 (J)TS 150/166HP
Alfa Romeo GT 1.8 TS 140HP
Alfa Romeo GT 2.0 JTS 165HP
The set is made from extremely strong s6 tool steel. Parts are heat-treated and hardened to 40HRC under the protection of argon to avoid deformation.
For friction shims, we use the same material as OEM LSD clutches to avoid metal shredding. Therefore, shims are perfectly safe for long term usage!
Preload is provided with high rate springs, and we get a dynamic lock from 37.5° angled ramps. All of this together gives 25% progressive lock which increases with revs and vice versa.
All parts are made in the N7 quality standard.
*This is a completely NEW product, CLUTCH TYPE, PROGRESSIVE, NOT Phantom Grip***
Since we had a lot of questions about what the difference is between the infamous Phantom Grip and our product, we decided to write them down.
Many people tried Phantom Grip and left disappointed with the feeling that they had thrown their money away. Since our product looks similar at first sight, some of you are scared to try it which is quite reasonable.
We want to emphasize that our product only looks similar to Phantom Grip and that's where every similarity ends.
Without any further delay, here is the in-depth explanation:
1. Phantom grip locks a differential only by using high rated springs. However, our product has ramp angle on the central channel where the central axle passes through. This ramp angle provides dynamic/progressive lock exactly the same as OEM ZF LSD. When you press the accelerator, large gear attends to spin the plate around pushing the ramp of the central channel against axle increasing pressure several times more than preload.
Conclusion - Phantom has a radial channel and relays only on high rated springs. In contrast, our product has both high rated springs to create preload, and a dynamic lock from ramp angles.
2. Everyone is afraid of metal shavings as a side effect of Phantom grip which often destroys transmission in front wheel drive cars. Therefore we use friction shims between gears and plates. We use the same materials for friction shims from which we are making our LSD clutch plates. This material gives them high resistance and longevity.
3. Materials that we use in production are only the highest quality tool steel. We harden and nitrate the materials to achieve the highest quality surface finish possible. That gives our product the maximum durability and lifespan.
4. Our products have proven themselves on many race cars on Hill climb, Circuit, and autocross tracks. The drivers using our products achieved up to 5 to 10 seconds better times than personal bests with factory differentials.
If you have any further doubts, visit our Racing Diffs YouTube channel to see how our performance products work.
si link-ul
https://www.ebay.de/itm/Progressive-Lim ... 3807303912
alfa romeo gt 1.9 jtdm
ex. alfa romeo gt jtd,150 cp
ex.alfa romeo 145 1.9 jtd
ex. audi 100 2.0 D
ex.bmw 520i
ex.lancia prisma 1.9 TD
ex.olcit
